I haven't had my R32 GTR for long now and it seems to me the more I look at it, the more I uncover (I'm saying this in a good way). Here's a list of what I have found.
Blitz Access ECU
Blitz BOV
Aftermarket Intercooler (I figured after seeing a few other GTRs that my Intercooler was enormous in comparision to theirs and putting in a front bar mesh to hide it was impossible)
Aftermarket suspension (well seeing as my shockers and springs don't look stock)
And this is what I had already knew before I got the car:
HKS Airpods
Greddy Profec Boost Controller
TRUST 3.5 inch cat-back exhaust
Z Airflow Meters
There is also a possibility that there may be aftermarket turbos seeing as the car was boosted at 14psi before I bought it (now running stock boost). I don't know how or where I can get a good look at them to find out.
My question is...From the mods you see here, can anyone give me a rough idea of what power figures I can expect??? I'm looking to have a dyno tune done within the next few weeks.
https://www.sau.com.au/forums/topic/74472-loving-my-gtr/
nice! love the car maverick, I was after a black one, but not enough at auctions in good nick
its funny how they tell you about somethings, then the car rocks up and you find all this stuff!
MINES ECU
OHLINS suspension
NISMO arms
NISMO bushes
etc etc... gotta love the japanese
mark
https://www.sau.com.au/forums/topic/74472-loving-my-gtr/#findComment-1368883
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
