Hi guys,
just thought I'd show off the HICAS lock Kit I Designed and manufactured for my R33. I'm pretty happy with how it turned out.
It replaces the rack/motor, rose joints attach the new shafts. The other end of the shafts screw into the existing outer joints. I could have got away with screw cutting the original shafts but I wanted the be able to swap back if need be.
Tell us what you think
Aaron
https://www.sau.com.au/forums/topic/74568-hicas-lock-bar/
Nice piece of work. Looks like it's well designed. What grade of ally billet and what rod material are you using?
I'd recommend rotating the rose joints so the grease nipples can be accessed on the car though.
I've also seen one that uses longer rods with the rose joints directly bolted to the subframe. Might save some machining and material.
https://www.sau.com.au/forums/topic/74568-hicas-lock-bar/#findComment-1370396
I can't remember what exact grade the aluminium was, i know it was a structual grade tho. The rods are M238 tool steel(P20).
I was thinking of making longer rods going directly to the subframe but i thought that i'd replicate the geometry just in case it was critical. Having said that the difference in the angles envolved probably wouldn't be too great anyway.
https://www.sau.com.au/forums/topic/74568-hicas-lock-bar/#findComment-1372750
A good high toughness steel like that should be fine to run the full length. The loads ar not great and you'll save a bucket on the ally.
Interesting choice of steel though. Used in the plastic moulding industry a bit.
https://www.sau.com.au/forums/topic/74568-hicas-lock-bar/#findComment-1375089
I'm a toolmaker by trade, but i specialize in CNC machining, CAD modelling of electrodes and EDM operations. That explains the steel. Figured i'd go for P20 as it's pretty much indestructable
Actually the aluminium only cost me around $35, through work tho. The full length rods would still be cheaper but they wouldn't look so fancy!
https://www.sau.com.au/forums/topic/74568-hicas-lock-bar/#findComment-1375528
Fitted my lock yesturday,
had to make a slight adjustment as it just fowled on the subframe, nothing major tho.
My mate and i wheel aligned it by eye and got it within 1mm each side! How ARSEY is that!!!
An easy $50 for the bloke that wheel aligned it, although my frount end was out by more.
Everything is working good so far
(touch wood)
https://www.sau.com.au/forums/topic/74568-hicas-lock-bar/#findComment-1378832
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
