  • Replies 62
Originally posted by URMINE
hahah it aint even got show :D hahah its got those fully wheels and thats it!! the bitch is to scared to take it out so he gets mark to drive everywhere!!!
pfffftttt
i just get mark to drive coz i dont have money for petrol :D
plues marks car has more power than all of our cars put together
https://www.sau.com.au/forums/topic/7459-mrslim-skyline/#findComment-110621
