I had the classic old age R32 gtr experience the other day coming down the freeway. One of the turbo's decided to die leaving me with the unenviable task of deciding how to go about a fix.
I've got most of the bits and peices off now and by the looks the good old rear turbo has done a seal and the front one is not real flash either. Both have a nice little puddle of oil in the compressor housing although the rear one is more like a 'pool'.
I was kindly offered a second hand unit assuming one turbo to be shagged but, since I can see a fast repeat of my present situation and all the mucking around repaeted I am considering a rebuild on both. Just wondering if anyone has a place they have used and prices for going down this path. Alternatively if someone knows of a person getting rid of some standard R34 gtr units?
I'm not necessarily wanting an upgrade in power since the motor is a bit old and the budget for the support accessories is just not there.
https://www.sau.com.au/forums/topic/74687-gtr-turbo-rebuilds-in-perth/
What's your budget? The R34 GT-R standard turbos are ball-bearing, but still have the ceramic exhaust wheel. You'll need to go to some form of N1 turbo for the steel wheel.
Here's a document outling most of the Nissan and Nismo GT-R turbos that were released and their specs:
http://www.ipixel.com.au/temp/nismo-turbins.pdf
Cheers
Brendan
Well, definitely give Grant a call. He rebuilt a set of N1's I had on mine that I sold ages ago. He can pretty much just rebuild but with a steel wheel instead as mentioned. While everythings off, it's a good change to replace dump pipes & front pipes too (if they haven't been already).
I use ATS in O'Connor.
He rebuilt, Hiflowed, and put bigger (t4) comp and exhaust wheels on my old VLT T3, lasted years (Still Going) & performed very well (340rwHP on 14psi) was about $1100 to perform.
Cant imagine it being any more $$$ to do similar to a GTR Turbo.
I rang him last week but he is on Holidays I beleive...?
A bit off topic..
But i was just wondering if you kind folk could give me some rough ballpark figures on pricing for fitting Turbos.
1. How much would it cost to re-fit a set of turbos (no more different than the stocks, ie just replacements)
2. How much to rebuild a standard GTR turbo?
3. How much would it cost to fit a full exhaust - turbo back?
4. How much roughly for 1 + 3 toegther from the same workshop?
5. How long will it take for #4 to take place?
- If any one could just give rough figures, from what you know / heard/ had done urself, etc. It would be greatly appreciated. All to a GTR btw, if i didnt make it that obvious :D
Thanks.
  • 3 weeks later...
just finished installing the new turbs.
I found that...
*the factory manifolds need porting and port matching.
*the factory dump pipes are crap, if your stuck with them they get some die grinding action too.
*brute force on the seized flare bolt water lines breaks them, I even tried a blow torch to no avail.
Now I've got some 700cc injectors on the way it's fast approaching tune time. I rang the boys at hyperdrive and they are snowed right under. I am happy for them but, i need a tune and since my first prefference for tuners is booked up does any one have a suggestion for another place that does datalogit power fc dyno tunes?
    • You know what, I am enjoying your updates, but I have to say it is pretty poor form to walk into a shop that is paying for space and stock on the floor, try all their seats to work out what you are happy with, then buy somewhere else. If everyone did that the shop will be out of business with no opportunity for anyone to try a seat before buying. 👎
    • Good work, and thanks for posting up your solution for future people!
    • Yeah mate that’s the plan, I just want something I can have fun in and work on during weekends.  There’s really only 1 road fit to drive the car on and luckily is been redone recently.  I do want to tune it next year sometime, no dynos here so I’m looking at an ECU that can be remote tuned.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
