im haivnig problems with boost in my 32 im not sure whats the problem is
in my first gear boost doesnt seem to hit (or very little) when i rev past over 3000
and then in second gear it only seems to go up to 4 psi even wen i pass 4500 revs
but in 3 and 4 it boosts up to the normal 7 psi
i dont understand why ?
i got a r32 gts-t 1992 it was originally an auto car converted into a manual
the cars got about 150,000 km on it.
is the turbo going out ? or is there anohter problem ?
https://www.sau.com.au/forums/topic/75156-problem-with-boost-in-my-32/
not sure how can it be a leak when it can hold boost when im in 3rd and 4th gear
and i bought the car with a auto to manual conversion already.
no i dont hear any ticking noises
except for this weird one wen i got over 100 km i can hear a ticking noise
When I bought my R32 it had a 108kph+ speed alert ding dong thing that could only manage a ticking sound after I wore it out on the freeway.
Just a thought.
I thought RB20's ran 10PSI stock. Unless you have a different turbo or a BC?
are you working off the stock boost gauge or an aftermarket one.
cause the stock one doesn't read PSI.
just a thought.
you still didn't answer if this has always happened since you bought the car or recently.
if this only just started hapening now, have you made any recent changes?
very true 'Cubes' as soon as i put my exhaust system on the boost jumped to 10-11 psi. for the other question about not hitting boost well my best guess is that u might have a leak in ur intercooler pipes, check them all and check the standard bov it might be leaking.
how does putting an exhuast on a car increase its boost ?
If you dont have a boost controller eg. AVCR wouldn't boost still be controlled by the wastegate ?
what is the stock boost on a 32gtst anyway ?, some say 7 some say 10. Im getting an AVCR soon and i want to know what is safe to run. I was thinking 12 psi....
it makes it rise due to less backpressure.
the enemy of a turbo car is backpressure in the exhaust.
having one free flowing gives good gains in many areas
as for manual/auto ECU, that wont make much of a difference
i have a similar problem...
standard my car ran 11psi with a Autometer boost guage...
I noticed that same prob, when boost kicks 2500-3000rpm it feels as if its loosing it, and at about 5k its comes back.. didnt register on the boost guage but..
Hooked up a Turbosmart dual stage boost controller.. and it does the same thing but worse.. 90% of the time it does it... sometime it works and hammers..
Im thinking it has somehting to do with the fuel cut as im running 13-14psi boost...
Bu then again.. it was doin it before i strapped the boost controller..
R32 gts-t run 10-11psi stock
My car was also converted to manual from auto... but didnt have the problem after the conversion..
it doesnt change the spring.
my understanding is (without even bothing to be technical)
By not leting the gas out freely, the turbine cant spin as freely.
If the rear is going no good, the compressor isnt going to go any better either.
So you make the rear work, and the front follows suit and the whole circle goes a lot nicer
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
