http://www.mgccsa.org.au/vintagec.htm
Also, check the 'Hill Climb Sup Regs' PDF link on the left menu for more info.
I think the address is:
Collingrove Hill Climb
Lot 100, Hill Climb Road
Angaston Rural
This is where the WRX club use to have one of their track events, wish SA had an official SAU club.
Hillclimb - cool! I opened the Hillclimb Pdf, that indicates the Hillclimb to be on the following weekend 12 June 2005.. is that a second climb or the actual date? Let us know as I'm quite keen too
oops sorry, didnt check the dates there. The one 'jager' was referring to is this one - http://www.nissansilvia.com/forums/index.p...showtopic=91758
The track is 7kms SE of Angaston on the Angaston to Eden Valley Rd, if you get lost Im sure the locals in the Barossa can direct you.
OK, from town the easiest way is as follows.
1. Go straight up Main North Road
2. Go around the Gawler Bypass and keep heading along the Sturt Highway towards Nuriootpa.
3. You will come to a fairly major turn off to Tanunda on your RIGHT, via Gomersal Road (possibly Highway). Take this all the way to the end.
4. At the end turn LEFT onto the main street of Tanunda.
5. Continue down the street through Tanunda untill you come to a S-bend/railway crossing and turn RIGHT at the SECOND Road. (you want the one that is almost directly ahead, not the one back towards Tanunda)
6. Follow this road for a while ignore the first sign to Angaston(I've oly been that way at night so i don't really know it.) go over a train crossing and past the VINPAC factory on your right.
7. You will come to a cross intersection with a sign saying Angaston to the RIGHT , follow that. This will take you up the Main street.
8. When you reach the end of the main street you must turn RIGHT.
9. Follow this road past the Collingrove Homested, keep going untill you see a sign for the Collingrove Hillclimb on the left. Turn down the dirt road immediatly after the sign.
The gate to get in, is on the left, By this time you should have a pretty good idea of what's going on!
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
