I have one installed in the center console -  the detectors are mounted on the front & rear bar (for alerting to cops coming up behind me) - it picks up lasers and radors. You wouldnt know it was there if you didnt know where to look. It has always gone off with plenty of warning and is set to not go off at doors etc.
what model number is this one ?
i'd be looking for something similar to that
']im decidin whether to purchase the bel rx65 or rocky mountain. I know the rocky mountain is developed usin military technology. Rocky mountain is also very competivitly priced, and according to their website, they are faster then the beltronics. Only thing stoppin me is the fact that beltronics has such a good reputation. Ive seen one bloke sellling the rx65 for 500. If we manage to get a couple of blokes together we could possibly get it between 450-480 dollars a piece. Anyone interested??? I'll find out today wether he'll budge on the price.
Cheers.
Paul
make sure you can turn k and x band off, otherwise the radar detector, no matter what brand will be useless. important ;)
2. It is only used on the car mounted radars (and unless you do a lot of country driving these are few and far between)
On the contrary - There are bulk coppers on the freeways and suburban streets with K-band vehicle mounted radars. And my last big fine was at night driving on a city street and got done with a vehicle mounted radar :)
K-Band is used by most vehicle-mounted-radar cop cars to detect your speed. Why would you turn it off?
Pretty stupid.
ok then leave k band on.
It will go off every 30 seconds... how effective will that be?
It doesn’t take a genius to realise that if your radar detector is going off so often it will be highly annoying and also it will make you much less likely to react when there is actually a multinova or camera.
I will repeat the best and most effective setup for a radar detector for city driving is to use it primarily as a multinova detector and to leave k and x band off.
If your radar detector doesnt let you turn off k and x then get a new one.
This is not an opinion, it’s a fact.
I used a Bell 900 for quite a while and found it to be worthwile.
Every day when I went to work from Mandurah to Bibra lake - it was like a mine field of speed cameras/police.
It used to warn me in adequate time and I found it usefull. If your an idiot driver who thinks that they can speed all the time and be saved, forget about it.
The radar actually made me more aware of speeding and when it beeped it reminded me to slow down. Was very impressed. Im just annoyed that they are illegal in melbounre. If we had radar detectors here, the vic goverment wouldnt make any revenue.
Had one, got my window broken into and stolen!
My stupid ass fault for not taking it down...
Had it for a few months n never saw a single detector, got stolen and went past one within a week.. lol just how things work ay
I didnt find K band was bad at all, but if u leave X band on dun go past ANY shops beep beep beep hehehe
in one of my mod's can turn x band off, i herd police dont use x band anymore, but for sum reason im speeding less with it :S, havent found a speed cam to try mine out but worth having one and all.
actually i have but it beeped when i after i drove past, got o learn the best place to mount this thing, pointed around and it picked it up like 300-500m away. soo im not too confident with these things.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
