CART bores me. I wish they had more Rally coverage. They should also get better coverage of the Le Mans series, and i wonder if broadcasting networks know if they could get great ratings with JTCC over here. Oh well. Motorsport is Motorsport. I'll be tuning in to whatever i can.
Who here likes the JTCC? I've found some videos on the net, but i lost them when the computer died a month ago. I'll try hunt them down again for those of you who like JTCC.
Ryan
https://www.sau.com.au/forums/topic/755-this-weekends-events/#findComment-17480
Well, to see some real racing, the State Championships are on at Eastern Creek this weekend.
The real races are on at 12.00 and 4.00 Sunday, but there are also on Formula Ford, Formula V, Improved Production, HQs, Sports Cars and Sports Sedans racing in between.
https://www.sau.com.au/forums/topic/755-this-weekends-events/#findComment-18862
Well, all the sports sedans are pretty over the top! There was an incredible Jag XKR at the last meeting that did a last to first run three races in a row!
I've seen two Rx7s, but I'm not sure what they run - most of them are Chevs these days.
https://www.sau.com.au/forums/topic/755-this-weekends-events/#findComment-18889
500hp! Not bad for a little 2L up against all the V8s.
Still, no wonder those cars break so often! There's also a fiat running a huge turbo something. Very expensive way to race - but about as quick as a supercar.
If you head out, drop by the Daewoos & say hi.
Duncan.
https://www.sau.com.au/forums/topic/755-this-weekends-events/#findComment-18930
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
