  • Replies 162
Yeah guys, i wouldnt worry until we get some definative results. If the Magic cat fails, ill take it back and get a refund! It shouldnt be up to us to test it; but it'll be interesting. Thats IF it fails. im with shif_tea above^^^^.
Should it not be as simple as the company distibuting "Magic Cat" providing documentation to prove that their Cat Converters meet ASE or ADR ( or whatever they are ) requirements / regs ???? It just seems far too simple for the distributors to clear their name and get back on with selling their product........ :confused:
I guess on the other hand.......is there any documentation available for the "Catco" Cats that says "it" is approved for use in Australia under ADR's etc ??
I know the US / California regs are more strict than ours, but that does not mean by default that the parts are accepted for use in AUS.
I guess another question would be: Is ASE Engineering Approval required for the fitment of one of these cats since neither is OEM fitment.
Not trying to stir up any $hit. Just throwing a few more bones out there for all to chew on :(
Quick update;
I have a new Magic cat for the test
Thanks to BATMBL, I now have the measurements of the Catco (flange to flange is 317mm)
So I can now get the Magic cat's flanges welded on to those dimensions
That will make a swap over easy, if it is necessary
Thanks to ABFLUG we have a RAWS standard facility to test the emissions
I will post up more progress as it happens:cheers:
Quick update;
whilst you are at it should you want to compare to a genuine GTR car I have one sitting around. would be a good basline.
1. What diameter are the flanges/exhaust on the test car out of interest?
2. Still planning a dyno test?
3. My plans have been a delayed a little, so if you need another Magic cat for testing I have one sitting on my floor :(
Lucien.
Hi LW
1. 3.25"
2. I know the magic cat doesn't loose any power over a 3" piece of pipe on a car with 300 rwkw, already tested that several months ago. If we have time when tuning the Stagea I might do a back to back comparing the compliance cat with the Magic Cat. But I already know the compliance cat is crap, so it won't tell me much.
3. Might take you up on that, have you had the flanges welded on yet? If so what's the flange to flange measurement? (Hopefully ~317mm).
It has been my experience that genuine GTR cats are very good. What is the flange to flange measurement? (Hopefully ~317mm). If it is, then I might take you up on it as well, that way I can do a 3 way back to back. If BATMBL wants to loan me a Catco, I will make it a 4 way, emissions and dyno test. As long as ABFLUG doesn't mind doing 4 emissions tests.
PS; Julian/Ben/Martin if we do this, and I write an article, will you publish it?
No flanges welded on:  its still in its (dodgey) box and bubble wrap from Magic.  My interest -- hence the question -- in the dyno test is more to see if the Catco also has no negative impacts on performance.
Cheers,
Lucien.
This is growing all the time. If I borrow your Magic Cat, it will come back with stainless steel 3.25" flanges welded on it. Is that OK with you? Let's take this off line via PM if you like.:(
I'm excited!! this is the showdown of the century, beats all that shapelle corby sh1t for intrigue and suspense by far!! they should make a drama miniseries about this i reckon!!
EDIT: SK if those girls in your pics are in your crew, can i be too?? I'll do whatever you want, fetch drinks, clean the floor, polish your engine bay (thats not some sort of sexual metaphor either, it was literal). I'm beginning to think that i'm definitely in the wrong field!!!
I can see it now:
"Its a story, about a man and his Catalytic converter. Stuggling against the odds to clear his name, and finally be re-united with his exhaust"
Rivetting stuff, reckon we could get Russell Crowe to play the lead?? And someone like Al pacino to play BATMBL's part. hahaha
Ready when you are SK just let me know.
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
