The Stagea runs full ATTESSA (like an R33 GTR, but with different calibration), so there is no one torque split, it is infinitely variable from 100% rear drive to 50/50. The ATTESSA controller determines the split based on the inputs, speed, engine rpm, gear, throttle position and most importantly G forces.
It should not be compared to the simplistic 4wd split that we see in front wheel drive supplied 4wd's. Some of which use the ABS sensors to detect wheel slippage, which is far too late in the equation. Plus they can never go more than 50% rear drive, which limits their handling envelope.
Sorry guys, still learning about the Stagea. So as with the GTR's, the tourque is rear derive untill there is slip? Can ATTESA controllers be implemented to the Stagea?
OC
Nope, there is no waiting for slip. When the G forces indicate a portion of front drive would be beneficial, then the ATTESSA supplies it. It is proactive, not reactive. ATTESSA controllers would work on Stageas, calibration may be interesting though.:cheers:
just on the same topic sorry to hijack the thread but i was wondering if sydneykid could tell me abit more about the attessa setup as i got a few q's :)
1. does the attessa "release" any drive from the rear wheels (like traction control) when engaging the front wheels or does the rear wheels always drive constantly the same???
2. does 4wd engage on take off launches or is it only in 2wd for the intitial take off?
3. so the front wheels engage (i remember u said its proactive not reactive)before it would wheel spin on take off or low speed coming onto boost?
4. if i release the pressure off the transfer case clutches by removing the hydraulic line will that cause any damage to the clutch packs or tranfer case in general or is it only damaging when the line holds the pressure?
5. what percentage of driving in the attessa pump on? or is based on how u drive? and how much u put ya foot down?
6. does the attessa pump have a constant power supply and an ignition supply? because im wondering why my attessa pump is staying on all the time, its as if its only hooked up to the constant power or something, though it only starts running when i start the car. or does it sound like a sensor issue? its coming up code 75 on the attessa ecu but i still aint got any info on what it means :confused:
hopefully u can answer some of them if ya dont mind ;)
cheers mate :)
Brad
hopefully u can answer some of them if ya dont mind :P
cheers mate :D
Brad
Hi Brad, wow that's a few questions, my suggestions follow;
1. ATTESSA is a torque sharing system, if the engine has say 200 ft lbs of torque output and the ATTESSA says 100% rear drive, then 200 ft lbs goes to the rear. If the ATTESSA says 20/80 then 160 ft lbs goes to the rear and 40 ft lbs goes to the front. Remember Newton's law, energy can neither be gained nor lost.
2. It depends on the G Forces, I guess a slow take off is 100% rear drive and the faster the take off (G Force) then more goes to the front. Though I have never seen it get to 50/50 on take off. The ATTESSA is smart anough (programmed) to know that the weight shift to the rear means it will have more traction there at high G Forces.
3. Yep it doesn't wait for wheelspin, the G Force sensor tells it there is less chassis acceleration than engine (rpm) accelleration and/or speedo accelleration. In a pure drag racing application, with a high power engine, the ATTESSA controller does not have the ideal programming. That's why the drag racing GTRs have manual controllers or add on electronics.
4. Zero hydraulic pressure = no preload on the clutch plates.
5. It is infinitely variable
6. At all times, when the engine is running, our Stagea has hydraulic pressure in the ATTESSA system. That pressure stays for some time after the engine is switched off.
Sorry I can't help you with the error codes.:(
so the stagea attessa computer would be better than the r32 gtr attesa computer?
would it be worth the effort to wire the computer and sensors in a r32 gtr?
steve
Hi Steve , I don't believe that you can, the data transfer rates are different as are the sensor voltages.:D
hey sk thanks for the info again :rofl:
so the attessa pump runs ALL the time that the engine is running?
also how does running different width tyres on the front and rear effect the attessa? like 265's on the rear and say 235s on the front, what what it cause?
cheers
Brad
hey sk thanks for the info again :P
cheers
Brad
Different WIDTH tyres implies different CIRCUMFERENCE tyres (though you can play with the profile to get them closer). Thus one revolution of the front wheel will take you a different distance than one revolution of the back wheel.. Unless you car is growing (or shrinking) in length :-) that would imply either wheel slip or that you are driving the front/back wheels at different rates all the time...
Ian
cheers
Brad
As Ian posted, width is irrelevant it is circumferance that matters. Otherwise the front wheels will doing different rpm at the same kph than the rear wheels. The ATTESSA clutches will have to slip to accommodate this, that generater unneccessary heat and wear.:P
... and different width tyres DO have different circumferances (as I pointed out..).
Not all the time, a 215/65/14 is the pretty much the same diameter as a 225/50/16 or a 245/40/17 or a 285/30/18. Noting that the diameter varies as the tyres wear anyway.:P
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
