hey guys just been looking at some dash's of other peoples skylines and realised they arnt like mine
i was allways under the impression my instrument cluster was like that from factory, but i could infact bewrong (btw its a s1 33)
my second question is: i just installed the boostguage the other day, and is it normal for it to be reading 1psi while the car is turned off?
thanks
-Ruffels
https://www.sau.com.au/forums/topic/76718-is-this-stock/
the white bit ive never seen before, probably just an el kit or white background upgrade
i dont see how the stock guage should be reading 1psi? when the car is off or at idle its -500mmhg which is absolute pressure, its definetly not 0psi or 1psi
https://www.sau.com.au/forums/topic/76718-is-this-stock/#findComment-1405271
strange that Bigmicky lol coz my mate dropped it when we installed it... it still works fine... but instead of reading 10psi when i full boost it reads 11psi, which would explain the 1psi lol
can it be fixed?
and does anyone have any further ideas on the guage surround in the dash?
thanks guys
-Ruffels
https://www.sau.com.au/forums/topic/76718-is-this-stock/#findComment-1405284
and yeah... ive still got the reciept, packet and all for the boostguage, i bought it from ricer barn.. do u recon they give me a new one if i take it back.. or wil they tell me it has to be repaired by speco?
-Ruffels
https://www.sau.com.au/forums/topic/76718-is-this-stock/#findComment-1405285
i reckon some one has just put that in the back of the cluster, and with your boost guage, i installed my boost guage myself, when connecting the constant make sure u connect the right one. And when i turn the car off, it ends up reading 1psi, but as soon as i turn the car on it auto zero's itself and is back to zero.
ive got an autometer tho, so its possibly different
https://www.sau.com.au/forums/topic/76718-is-this-stock/#findComment-1405765
You open up the cluster.. paint that bit.. aftermarket facia cards are available in the correct size in japan - you can get carbon fibre look, etc. So it's either one or the other.
With the specco, somebody has shoved something in there too far, and it has jumped up. You can get inside and there is a spring mechanism - you kind of shove it back and you can adjust it up or down el'dodgo style. My old gauge often needs stuffing around with to get back on 0psi.
sorted..
https://www.sau.com.au/forums/topic/76718-is-this-stock/#findComment-1405861
As i understand it:
The boost gauge will only read vaccum / boost when the engine is running. The gauge will sit slightly eityher side of zero depending on what the air pressure (ie - the weather) is. Doesn't always mean that it's been dropped.
https://www.sau.com.au/forums/topic/76718-is-this-stock/#findComment-1418856
Standard air pressure at sea level on a 15'C day is 101.3kPa, or 1Bar. That's 14.7psi iirc. Give or take a little based on daily changes.
Yep, the gauge will only display something other than zero when the engine is running :uh-huh: but 1psi is the air pressure at around 28,000ft.
Mark
https://www.sau.com.au/forums/topic/76718-is-this-stock/#findComment-1419360
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
