i gotta r32 gtst.. hicas is **** and i need to remove.
im guessing that putting a lock bar in would be the best way as it sits solid, but on the r32, if i was to cut the hicas wire (havnt searched on what to do here) would it be as stable as having a lock bar.. whats the pros and cons, as im on a budget
cheers
https://www.sau.com.au/forums/topic/76742-hicas-lock-bars-vs-pulling-the-fuse/
I have my HICAS computer unpluged to fix my HICAS problem. The steering is a bit heavier but the car feels OK. I don't feel the wheels floating around.
But I am about to rip my HICAS out as soon as I get all the info on what needs to be done.
I'm almost certian HICAS is fail safe, so the power dies (fuse removed) the steering will be locked - although I have heard it can still move slightly so locking pins are a good idea.
Cutting the wire will make the car highly dangerous.. as the wheels just float there moving around.
I think even if you remove the HICAS comp. or fuse, disabling the HICAS system.
For a safety issue you couple possibly have some shims made similar to that of the Tomei set up.
If you have any issues with the HICAS warning light coming up on the dash, simply remove the globe. :D
In an R33 what you have is an electric motor connected to a steering rack with no power going to the electric motor (no fuse). So the only thing stopping your rear wheels from steering is the resistance of the electric motor to rotation from the steering rack pushing against it. In addition, since the steering is not moving, all of the loads are being excerted in one spot on the rack, this will cause it to wear faster as it is not sharing the load. Hence you will get a sloppy spot on the rack which will enable the rear wheels to knock around slightly all the time.
Bottom lin,. not a good idea
Flipping the topic over....
My hicas light is on 24/7 and I want to enable the hicas on my line again...when I bought it, it was disabled and the guy I bought it from said he just disconnected something from the back.
I just had a look and the rear fuse box has a 20A fuse in the hicas spot which is all good (although i will remove the fuse tommorow to check if its blown).
I noticed 2 silver boxes near the fuse box hanging from the roof. The top one larger than the bottom one. If anyone knows the boxes im describing then are any of these 2 the hicas computer? If so i guess something could be disconnected from them.
Any other places I can check for a loose wire/fuse before I realise he sold me a ****ed hicas system and said it was just disconnected? :P
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
