Thought I'd start a thread on the 30DE hybrids. There is a biiig discussion for the 30DETs in the turbo section, and I'd like some discussion and past experiences from anyone here that has done this conversion or is unsure (like me :)).
Benster seems pretty keen on this conversion, and I'm still looking into it, to see if the power gains will be worth doing. Don(?) I believe has done this with his red wagon, and Megalla.
Anyone have dyno graphs? 1/4 Mile Times? Costs Involved?
So far:
Head: RB25/RB26 (26 would be better but costly)
VVT: Would be better for NA applications, but easier without VVT
Block: RB30E
Pistons: RB25DE Pistons (Benster has confirmed to give a 10.5:1 CR) What about lightweight hypeuretic?
Oil Pump: I believe the stock RB25DE one would be able to be used?
Fuel Pump: I believe the stock RB25DE one would be able to be used?
Cams: Stock? Bigger cams?
ECU: Chipped 32? PFC???
https://www.sau.com.au/forums/topic/76797-rb30de-hybrids/
check out www.r31skylineclub.com for more info on the hybrid conversion
i think this has already been mentioned in the turbo section but anyway...
im pretty sure they have dyno charts and a 1/4mile time...but im not sure
ill check now then hey!! :thumbsup:
https://www.sau.com.au/forums/topic/76797-rb30de-hybrids/#findComment-1406664
very impressive 467hp (348Kw) @ 6000rpm - 17psi compression
running a TO4E turbo and PULP and i asumme that the power is at the flywheel (cause the article says that the engine went to the engine dyno...duh!)
and it has links to a mag article that has done the same thing - i think that the article is exactly what was done there - the website was just what the mag said - thats what it looks like anyway
https://www.sau.com.au/forums/topic/76797-rb30de-hybrids/#findComment-1406673
A friend of mine has built one of these, last dyno he got 137rwkw can't remember the torque figures, he did a 15.2 1/4 mile, meremere NZ.
After having a few problems he ditched the VVT and put in a RB20DET intake cam. He has used stock fuel pump and oil pump, but added a adjustable fuel pressure regulator for good measure.
https://www.sau.com.au/forums/topic/76797-rb30de-hybrids/#findComment-1407766
usherly, thanks for the help but I was talking about the 30DE...
it is isn't it?
ohhhh...do u mean the power stats
but they are from a rb30DE hybrid?!
sorry i don't get what u mean
:confused:
EDIT-----
woops sorry - i just realised the rb30DE not the rb30DET
hahahahahahahahaha...damn im stupid
still it gives a lot of info on the pros and cons of it and why they choose what they did
ohh..u know anyway - u read the site, im just crapping on now
https://www.sau.com.au/forums/topic/76797-rb30de-hybrids/#findComment-1407890
Rachael: 137rwkw and 15.2 sounds pretty good... Don(?) on the forums here (with the red wagon) has managed a 14.7 - that is with pretty much rb25 bits - pretty good :D
I am currently doing a little research into using the 26 head, and bigger cams and lightweight pistons - This is the tricky bit, cos it starts to get quite expensive - and may as well go the turbo route... There doesnt seem to be many people who have done a worked RB30DE hence the lack of power figures, torque figures and 1/4 mile times.
Still keen on a N/A motor for something different, insurance and yet keep the power figures up without pouring too much money (and no nos :P)
From memory the R32 RB25DE (non VVT) had smaller combustion chambers than the R33 RB25DET. It has been 5 years, so don't count on it, best to measure it up first. If the RB25DE combustion chamber was the same size as the RB25DET combustion chamber, then you would get ~12 to 1 compression ratio with the extra stroke (capacity) provided by an RB30 crank ie 20% more capacity being squeezed into the same size combustion chamber.
Gary's thoughts on CR ratio's.
no worries Usherly - thnx for the input
https://www.sau.com.au/forums/topic/76797-rb30de-hybrids/#findComment-1408365
yep ive done it
rb30e with rb25de head ( r33 ) with vvt . has the rb25de pistons ( 10.5 -1 compression )
modified xf falcon tb now 68 mm throttle plate . rehashed rb30e extractors . rb25det injectors . malpassi adjustable fuel pressure regulator , bosch 040 in tank fuel pump . stock cams , head not modified just port matched to manifolds , stock rb25de ecu , apexi safc 2 fitted .
rb25de gearbox and stock non lsd 3.7 ratio diff
havnt had it on a dyno
have done around 30000 kms on it since march 2004 , no probs .
https://www.sau.com.au/forums/topic/76797-rb30de-hybrids/#findComment-1415644
i with stock parts (rb30e and rb25de) considering you own a gts25 it wud be eaily done under $1000.
I've seen Don's car on TV and it looks pretty good, his 14.7 wud surely give some stock gtsts a scare...
Most of us are under 25, and it certainly would be good on the insurance for an NA Motor to pull some nice power, torque and 1/4 mile times.
In the end I think I'd save on insurance for those 5-6 years it wud take for me to own a turbo motor....
Still doing a bit of research and provided most of the work is done yourself a full worked NA motor wud be around 4-5grand (pistons, head, ecu and tuning being one of the most expensive bits)
https://www.sau.com.au/forums/topic/76797-rb30de-hybrids/#findComment-1415739
yep ive done it
Thanks for the post! Any problems you ran into during the build?
Most of us on here would already have the RB25DE, so to build the engine, costs would be:
- RB30E bottom end ($400?)
- new bearings etc for bottom end ($200?)
- labour to fit RB25DE pistons and new bearings ($500?)
- new head gasket ($100?)
- adjustable fuel pressure regulator ($200?)
- new fuel pump ($300?)
- Apexi SAFC + dyno tuning ($500)
- Porting head ($300?)
Estimated total (please correct me, I just guessed the prices) - $2,500
How much did it cost you to build yours DON? Did you need larger injectors? Is the new throttle body necessary or just a nice addition to help it breath easier?
Would there be room for the bonnet to close still in an R33?
Thanks for your input :D
I don't want to go all out on an RB30DE with new pistons and cams and all the rest but I'm definitely interested in gaining an extra 0.5 litres displacement if the price is right. Otherwise I'll go the RB25DET or RB30DET option.
The RB30DET is more likely to add value to the car in terms of resale price imo. RB30DE would add maybe $500. RB25DET would push the resale price to just below a GTS25t.
https://www.sau.com.au/forums/topic/76797-rb30de-hybrids/#findComment-1415836
that's a pretty conservative guesstimate Greg - sounds about right.
Don runs RB25DET injectors.
The with the Rb30 block it will sit 30mm higher, so no front strut brace, but the bonnet will close.
Personally I'm looking into the bigger cams and using the rb26 head - the throttle body doesnt sit like the 25s so an added bonus is the strut brace *should* be able to be kept.
That said a 26 head is like 1500.... already.. :D
I believe resale isnt really an option anymore for skylines, there's so many on the market now and all with extensive mods done to them.
https://www.sau.com.au/forums/topic/76797-rb30de-hybrids/#findComment-1415859
You can get a cheap RB30E freshened up for $1300-$1800 depending on if you want it balanced etc. This includes gaskets.
The bottom ends go for around $100-$200 for a decent condition previously running motor.
I picked mine up for $150 running without the head as it was sold seperately.
A friend of mine picked up his RB30 bottom end for $100 with a blown head.
The rb26 head.. Good luck getting one for a decent price with manifolds and all the gear you need.
An Rb25 non-vct head with manifolds and everything you need goes for around $750-$1100.
I picked mine up for $750 as did the friend of mine.
Its not as simple as just porting as the head needs to be stripped and reassembled.
If you are going to do this expect to spend at least $800 on it.
You will need to spend another $275 on a VRS kit that includes a headgasket and all top end gaskets.
Replace the valve springs with either RB25DET items or RB26DETT items.
The RB25DE head and plenum won't allow the bonnet to close, the RB26 & plenum will.
I had my motor lowered around 13mm. If it were lowered only another couple of mm the strut brace will fit. It comes very close to the throttle body's inlet pipe clamps, this is where it fouls.
Resale with an RB30DET is likely to be less than a modified standard motor. UNLESS it has been registered.
https://www.sau.com.au/forums/topic/76797-rb30de-hybrids/#findComment-1415946
heres what i spent on it , will probably scare me when i add all this up .
r33 rb25de engine with harness and ecu $ 1100
timing belt , piston rings big end bearings and gasket set about $ 450
auto elctrician to wire it up $ 500
rb23 det 370 cc injectors $ 150 second hand
injectors clean and test $ 130
malpassi fuel press reg about $ 180
bosch fuel pump 040 , new about $ 250
throttle body mods , about $ 120
apexi safc new $ 475
now whats that add up too , gees thats $ 3355 .
mind you didnt do it all at once . the fuel press reg , bigger injectors and cleaning , bosch fuel pump were all done over a time span of about a year .
i built up the engine over 4 mths as i had time and money .
and i had a spare rb30e engine lieing around to start with .
THERES PIC OF IT IN MY PROFILE
https://www.sau.com.au/forums/topic/76797-rb30de-hybrids/#findComment-1415992
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
