Guest [ryan]
with the under age part, why? there are only two under age members, ryan and me, sure there will be more under age people as we get bigger but for the mean time I think that the both of us are mature enough to be a part of the overage member ship if it happens.
My $.2 cents[/quote:91c2ded908]
Because it may attract other under age members, who may make bad decisions and bring the club down if they are aloud to vote etc...
  • Replies 230
Guest [ryan]
yeah but i was just saying about us not new people.
yeah i know.. but like i said, if we get special treatment it may cause arguments and stuff with other new underage members. oh well someone will work it out..
here's some more logos
I was more thinking R34 After burners :P
but yeah that's general Idea...
I saw this nice Red R34 Chris's car shot by Boost!
That pic will be ferfect if I can find the damm photo!
it's red nismo R34 Skyline with number plate SKYLINE and beutiful after burner next to each side!
you give a try...VipersGarage.net
cheers
Joe
Guest MACATAC
Hey there guys, great to see you moving forward towards forming yr own organisation.
I see there has been some discussion over having associate and full membership.
Dont know if this helps you at all. Its just my HO. I was genuinely interested in becoming a financial member of SDU in the early formative stages. Ok sweet.....so i had a chat to one of the execs....Well seemed i could only become an assoc member(because i didnt own a Skyline) Hmmm OK what does that mean?. "You may not be eligible to vote, not able to gain discounts, not be able to enter certain events" Whilst it is not a big issue it was enough to put me off becoming a financial member.
There are ppl (without Skylines) out there who could well be genuinely interested in helping develop your organisation....just because they dont own a Skyline does not mean they dont have skills,and heaps to offer. IMHO dont become too elitist...keep an open mind, it could pay huge dividends in the long run.
I did become a financial member of a car club eventually. Funny part is i have a Nissan and now belong to "Club Lotus NZ". They are accomodating and welcoming and dont discriminate on this issue....one of the reasons they are such a strong go ahead organisation. In fact it is possible for a non Lotus owning member to become part of the executive if you have the desired skills.
Mac
cool does that mean we will be affiliated with cams?
and does that mean we can get (for non-cam lisence holders) able to get our cams lisence...maybe for a bit cheaper *nudge nudge wink wink*
nah i need to do my advanced driving course and get my cams lisence aswell
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
