Next time, wedge the breaker bar, with a piece of pipe to lenghten it, against the chassis rail, then disconnect the ignitor and turn the motor over on the starter.
I assume you are talking about the balancer bolt.
That makes it hard then.
I have a sprocket holder that fits in the balancer and gives me something to work against. Holding on the gearbox just has enough give to take the sting out of it.
Not sure if you've got the bolt undone yet but I had the same problem with my 32R a couple of months ago - this is how I undid it.
Use a breaker bar with a 1.2m pipe extension over the handle.
Put the car in 4th gear, pull on the handbrake as hard as you can, get someone to sit in the car and stand hard on the brake pedal.
With one hand put as much tension as you can on the bolt using the breaker bar and extension (I mean hang off it!) then using a sledgehammer whack the pipe as hard as you can and hopefully the bolt will loosen. I gave mine about 4 whacks before it moved.
I tried the breaker under the chassis rail and hit the starter method but that just stalled the starter. I think this only works on RB20 and 25's as they have 1/3 the torque on the bolt that the RB26 has.
Specified Torques are the same. Its more luck of the draw with how tight the bugger is.
... Its more luck of the draw with how tight the bugger is.
And that seems to be determined by how long it has been since it was last undone.
When I fitted the RB25DET to my R32 GTS4, I had to swap front diffs. On the RB25, the pinion bolt undid with the aid of an electric rattle gun. But the gun wouldn't come within a bull's roar of undoing the RB20's. Had to use a 4 foot breaker bar on a 3/4" ratchet head to undo it!
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
