  • Replies 41
Peter.  I want to run it that rich just to have a bit of a buffer zone as i will give it a hard time and just want to make sure its safe. Id rather sacrifice some hp and just make sure it doesnt ping. As with fuel thats the most that pump is gonna give at those afr's. Fabs gtr went about the same hp with a single 044 so im going to use 2 with a surge tank . Cams it is using are HKS 272 272 step 2 10.2 mm lift which isnt huge lift as they go up to 11.8mm on some. . As for target boost pressure this turbo should be in its efficiency at 24-27psi so thats what im heading for. Also lift the limiter from 8k to 9k when it has a fuel system to support it.
Why do you think it is the fuel pump? Have you monitored the fuel pressure on the dyno? If the pressure drops that means the pump is running out of flow capacity. With 13.8 volts via a relay and direct to battery connection the single 044 should have more than enough capacity to handle that sort of power.
:rofl:
ok cool
thats a pretty big buffer but ha each to there own and rich is safe
so by way of a the 800hp turbo at mid 20's psi with high lift cams and spinning it to 9000rpm you must be think around 600rwhp then at a guess.(or did you have a target in mind)
and if your going to spin it pretty hard what oil pump you using out of interest?
pete
sorry to hear about the box
Thanks yeh box is a bummer hopefully new one in by weekend. Im happy where it is at the moment as it feels nice to drive with not much lag and good top end. Im thinking in the mid 20's it may go near 600rwhp but until it does that i cant say what it will do but it is a good sign to be making good power at lowish boost. Its running a JUN oil pump.
I hope you have a large cost-effective supply of gearboxes...you'll need it
simon doesnt learn....
he went through about 8 or so rb20 boxes and still didnt learn
how many gtr boxes have to be killed :uh-huh:
car goes very nicely, was shotgun in it same say as the dyno run... can't wait till more boost and better tune
PLUS A DECENT GEARSET ;)
hey simon nice results :uh-huh:
pitty you sold me the spare gtr gearbox you had haha :)
goodluck and hopefully u can take me for a spin when its sorted to show me some single turbo power (and maybe ill convert mine to single haha)
cheers :D
Brad
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
