Friday Night Cruise Sessions - Palm Beach & Pizza Cruise - 24/6/05
Hey~~damuscat
did i c u last weekend in front of my place??u were in ur wine red??
hahaha.. yeah that was me. I saw your car on the road with the boot open but didn't see you until it was almost too late.. I gave the horn a quick toot and you probably thought.. "who's that weirdo?" :) j/k
  • Replies 184
Its not the mandarin center carpark - it's further down Victoria Avenue. You keep driving down until you see a shopping center on your left called Chatswood Chase and then take a left at the lights down to the carpark.
We meet close to the boom gates entry and you cant miss the Skylines that will be parked there.
Satanic, you can leave anytime mate, many people have work and or other commitments the following day.
Normally most people depart Palm Beach etc around 12am, depends on how things pan out.
oic~~
is it the shopping center next to the church?
so the lights is the one between the shopping center and the car wash place ,rite?
and then i take a left turn go down to the carpark~~
hopefully i ll find it~~
hey if someone leave me a Number will be good , i can call if i get lost
Joy, I will cruise past your house and you can follow me there.
I know where you live!! lol
yeah~~~
dat ll b kool~~
wht time u coming??
givmme ur number
P.S ALWAYS LIVE IN A PLACE COMES WIF A GARAGE
BL**DY H*LL EVERYONE KNOWS WHERE I LIVE NOW
I'm out.  New transmission needs 500 km no boost run in and 500 km low boost run in.
what does that have to do anything?
cruising is run in.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
