Hey I was just wondering if these power dips are normal for a standard computer?
I thought that it might be going into rich and retard mode. We tried setting it to 10 psi but the dips still remained, and we tried setting it at 13/14psi and it got 181rwkw.
Car is a 1996 R33 GTST
Mods:
3" Front pipe
GTR cat
3.5" HKS Cat-Back
K&N POD FILTER un-sheilded
GTR Intercooler
Bleed Valve set at 12psi
Do u think it may be getting too much airflow at 10psi aswell?
Any help would be appreciated
Thanks, Mike
https://www.sau.com.au/forums/topic/77612-r33-dyno-results-power-dips/
Yep the good old R33GTST standard ECU rich and retard strategy. If it's a manual then Power FC is the go, if it's an auto then SAFC, DFA or equivalent.
PS; I wouldn't be running the standard turbo at 12 psi.
wow that looks like mine but mine was a bit smother up top with mods at the moment being
3" dump and high flow cat
hks super dragger cat back exhaust
K+N panel filter
bleed valve set to 9psi
putting the cooler on at the moment then going to get it dynoed at different boost levels to see what happens with the afr at the moment it is running WAAAAAAAAAAAAYYYYY to rich i am not sure if my budget supports an pfc so i will prob just go with a SAFC and see how she gos.
actually thats a really good comparison graph. we both around the same peak but i make on avg 20rwkw more at each km/h interval. the stock dump pipe is my current restriction and getting that changed this week and gtr fuel pump going in
Hey buddy. My r33 is doing the exact same thing. Ive been told that if I get a power FC it will fix things as well, but for about $1600 fitted with tuning.. its a bit more than i wanted to spend. I've been told SAFC II should do a similar job too ($400+Tune), im currently looking at getting one. I heard PFC is better to get if you want to change turbos later on.
BTW these are my specs:
3" seperated dump/front pipe
3" highflow cat and stainless xforce exh
HKS Pod filter
turbosmart manual boost control (running about 12ish psi)
hybrid FMIC
so.. similar to yours really mods wise. Ive attached dyno sheet.. which is around the same 226RWHP is around 165kw@ wheels i think (correct me if im wrong)
Thanks for all of ur replies, do u think that if i drop the boost the car will actually run better, considering it wont be rich and retarding itself?
Thanks, Mike
yes. it wont be flipping out as easily until you get the PowerFC :(
well if you drop the boost just under the stock ecu airflow cut then it wont keep going into rich and retard mode so youll make probably the same power, but the curve will be somewhat normal instead of a yoyo like arrangement.
Same thing happened to mine on the stock ecu.... i put the boost down from 12psi to 9psi and the car made plenty more power and was a lot smoother to drive...
As mentioned above, get a PFC, although i only achieved approx 10rwkw peak power gain the car as so much more midrange you will be very happy with it.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
