Finally got the dyno graph up the following is how it appears
Blue 4th Gear - Bone stock nothing done no AFR was done on this day 141ish. done 7 months ago - note the dual stage kicking in.
Red - 4th Gear - 3" dump pipe, high flow cat, hks super dragger exhaust, K+N Panel filter, Turbosmart bleed valve set to 9psi
Green - 3rd Gear - 3" dump pipe, high flow cat, hks super dragger exhaust, K+N Panel filter, Turbosmart bleed valve set to 9psi
Conclusion: In stock form looks pretty clean. add a bit more boost and a few other things the ECU decides to go into over protective mother mode and pump way to much fuel in by the end of the run it looks like it was running at about 10.5 which is wayyyyyyyyyy to rich but still making ok power though you cna also see it starts getting a bit wavey up top.
Putting the FMIC on soon will probably just make it worse too so yea i will be looking at least an SAFC if not something else. Does anyone have any feedback on a tuned r32 ecu as the 33's cant be tuned from what i have been told. i think one of the guys toshi posted up in the for sale area that he can re-program them for a couple of hundred dollars which would be alot better than a SAFC providing its tuned right wouldnt it ???
You can't use an R32GTST ECU in an R33GTST, no VVT for a start, plus the pin outs are totally different. I should point out that in my opinion any ECU tuning not done on line (ie; off the shelf chip) is a GUESS, and every engine is different.
I can't see how an FMIC will make it worse. If it lowers the inlet air temps, you may be able to run lower boost (decrease the airflow) and make the same (or maybe even more) power. Less airflow would mean the standard ECU would resort to a lower (or non existant) R&R strategy.
The only time an FMIC would make it worse is if you choose to allow the lower resistance to increase the boost. But that is your choice, not the FMIC's.
Hey guys, i know this might sound side tracking abit...but im just curious, does it mean that running anything more than stock boost on standard ecu, will cause the car not to perform as well?
Assuming that the ecr33 has been modified with stock internals?
how do you mean it wont perform as well naturally it is performing better as you are making more power however you are probably not doing it the safest/best way if you are not using some sort of fuel/engine management
I was wondering would these power dips show up under WOT in 2nd gear aswell you think?
Also - I am thinking about getting a powerfc...
but I saw on the UAS website there is a graph for a car with more mods than mine and it is going well on stock ecu!!
208RWKW with good power curve!! What's wrong with mine and everyone elses??
FROM UAS site:
SKYLINE R33 GTS-T
* UAS RB25 Plenum & Intercooler
* 12 Psi
* Standard ECU
* Standard Turbocharger
* Cat Back Exhaust
* Pod Filter
208.4 KW AT THE REAR WHEELS
its in shootout mode with an intake temp of 34 degree's so its rounded to compare what power it would make at 25deg inlet temp, so its probably reading higher than it normally would. the plenum wouldnt make an ounce of difference and the stock dump would be a nice big restriction. heck my stock dump is holding me back at 170rwkw with powerfc
Brought my Skyline 4 weeks ago. Was stock standard but now has:
K&N Pod filter
Jasma cat back exhaust
Split dump and front pipe
Ball type boost control valve
Had its first dyno run this morning in 14 degree weather and made 178 rwkw.
Boost was set to 12 psi and my dyno chart doesnt show any of these dips in the power. The torque is also quite flat.
The mixture was VERY rich though, and the tuner said there was another 20kw to be found by leaning it out in the upper RPM.
Looking at upgrading to a front mount intercooler next but still trying to find an aftermarket one that has the GTR style end tanks, not the ones that look like only the bottom 3 rows are being used.
It just seems like that is a lot better than the curve most people are getting. I think I am getting rich and retard at around the 10psi mark with only a R34 intercooler. If you compare the UAS graph to others it seems that it is a very good stock ecu. I'm not talking about power. I'm more looking at the shape of the curve..
    • Agreed, I've never seen a 260RS specific manual. As GTSBoy said it will mostly be stagea other than the engine loom https://www.hgeconsulting.com.au/stageaservicemanual.pdf
    • You'lll likely have to make do with R33 GTR for engine/tranny stuff, and Stagea for the body. I don't know that there's even been an actual diagram seen in the wild.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
