OK guys just need some un-biased opinions. I've come to the conclusion that I need some type of fuel management aids. By looking at the dyno sheet, you can see some real bad dips (40hp near the end). I've been told that its the ecu and its retarding when running higher boost. (correct me if im wrong, this is just what ive been told by a few people as a 'possible cause')
I want to know basically if I should bite the bullet and just go for a power FC, or do the cheaper Super AFC II option. Also.. I can get the Power FC off these forums for about $980 delivered, but how much is this going to cost to get fitted and tuned? The SAFC II is about $400 delivered, but is this cheaper to install and tune as well?
BTW mods are
seperated dump pipe to 3" s/s exh, hks pod, man boost control, Hybrid FMIC.
https://www.sau.com.au/forums/topic/77715-powerfc-or-safc-ii/
the boost control itself seems to be a bit dip-py aswell, floating around 10psi..
ive got 3" split dump, 3.5" exhaust, pod filter, ARC 450 FMIC, Microtech LT-12 running a pretty stock config, except its a bit flat at the start of the rev range, and i get 270RWHP
(i dont have a picture of my dyno graphy handy, but its pretty much the same as yours, except at the start it gets more power pretty quick, then midrange it flattens off, then it jumps heaps towards the end, and begins to curve down a tad near redline, peaking at 270RWHP at about 135km/h, altho it was dyno'd in 3rd gear)
so it should be safe to say you could get another ~30hp, and a more steady graph with some decent management. :(
If you want to add hp by just changing the ecu & want to modify your car later on, PowerFC. The safc will give you the right air-fuel ratio though, it's just a question of budget. What boost are you running????
If that power dip is due to retardation a SAFC won't help because it only adjusts the fuel not timing I believe.
What did Lumpy recommend as he knows his Nissans so I would go with that.
Other than that I'm another vote for the PFC.
It plugs straight in and only has to be tuned as opposed to wired up then tuned so install and tune costs may not differ that much.
Cheers for the advice guys.
bnr#@ - Had the bumper off to re-fibreglass and paint, its back on now, driving around with a big fmic in front wouldnt be too smart :D
ossie_21 - Im running about 0.8ish of a bar. The car drives smoother when running lower boost tho, not so up and down. When running about .8, it takes off good, then tapers off then takes off again a bit. Feels very slow ;)
I think I may need to just bite the bullet and buy the power FC, its just $1600ish I can't really afford to spend at this time, but yeh chances are down the track I 'may' change the turbo, so power fc will seem like a better option
Just to throw a curve ball, sorry - but have you considered the Greddy e-manage?
It starts life as a SAFC, but can be cheaply upgrade to provide FULL management. Lap top programming etc. It really is a versatile ecu, cost a little more than the SAFC, but alot cheaper than power fc, especially initial purchase.
From someone that has done the SAFCII route and then gone the PFC, I would highly recommend going straight to the PFC. I certainly wish I had. If this means driving your car more sedately and saving the extra money, do it. I was very similar to you, had funds for SAFCII but not for PFC but in my opinion, the money i spent on SAFCII + tuning was essentially wasted cause the PFC is such a better tuning option.
Also, in relation to the dips, do a basic diagnostics. I had a serious dip in one of my curves at high rpm (and when i say serious, i mean 100rwhp serious) and this turned out to be a knock sensor wire come loose which a simple diagnostics detected. Plugged it back in, took it for a tune again and no dip. It may help, it may not, but hope it does :)
Yeh .. the group buy needs like 30 people tho. HASHIRIYA on these forums is selling power fc + commander for $1020 delivered to door, then put on however much to tune it. Yeh ive read that its a DIY job for sure.
Uneekwahn - $1600 was a rough supplied fitted and tuned price (with 1yr aust warranty)
Just wondering if its worth it buying myself, fitting it, then just driving it somewhere to tune, ive been told powerfc std settings is 'safe' but dont floor it until a tune. Anyone know how much it is just to do a first tune of a powerfc? Keep in mind i won the raffle @ hyperdrive on the weekend so i got a power run and dyno tune to value of $150 ;)
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
