Help R34 Fuse Panel - Translation please!
Hi Guys,
I've just picked up a 34 GTT and have no front wipers.
I can't see any blown fuses.
BUT, I have some fuses missing from the interior fuse panel.
Can someone please check this out this attachment (1 page PDF)?
Looking mainly for wiper fuse location, but if you're feeling energetic, I'm sure posting the full set will help out some of the ppl.
Thanks heaps!!
PEAR
Here's a sample of the 33 Fuse Panel - but I can't find anying on the 34.
SKYLINE R33 Fusebox
In Cabin Fuse box:
Left column, top to bottom
10A REAR WIPER
10A ANTI-STOP (ABS PERHAPS???????)
10A STARTER INDICATOR
10A ROOM LAMP
10A STOP LAMP
10A ELECTRICS
10A ENGINE CONTROL
10A HAZARD LAMP
15A FOG LAMP
10A TURN SIGNAL
10A METERS
10A ELECTRICS
Right column, top to bottom
10A SHIFT LOCK
10A A/T CONTROL
10A AIR CONDITIONER
10A ENGINE CONTROL
10A AIR BAG
20A BLOWER MOTOR
20A BLOWER MOTOR
10A AUDIO
15A CIGARETTE LIGHTER
20A FRONT WIPER
10A MIRROR CONTROL
20A REAR DEFOGGER
Ok, on the PDF, location #6 IGN 20A 'Front Wipers'.
It seems odd that they don't work... for an R32 or older it seems possible but an R34? I hope it's only a fuse thats the problem.
Thanks!! yes, fingers x.
from memory, I think #6 was missing.... I hope,
I know some where missing (2 or 3), I list them, would you be able to translate them too?
Thanks again,
PEAR
Was a missing fuse - wipers are now working!! Thanks.
The 3 blank spaces lets look as though they are ok.
Rezz, thanks again!!
PEAR
Interesting! Where is the interior fuse box? I had a quick look the other day and couldn't spot anything :thumbsup: Also, can anyone give me an idea as to whether the cigarette lighter is listed there? :P
#23 ACC 15A 'Cigar Lighter'
  • 2 years later...
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
