NEW ARIAS 88MM FORGED PISTONS AND RINGS
MATCH PORTED MANIFOLD
S/S DUMP PIPES
S/S FRONT PIPE
N1 TURBO?S- STEEL WHEEL
N1 OIL PUMP
NEW WATER PUMP
OS GIKEN CAM GEARS
OS GIKEN TWIN PLATE CLUTCH
NEW MAIN AND THRUST BEARINGS
NEW CAMSEALS
NEW VALVES AND SEALS
NEW GEASKETS THROUGHOUT
NEW IRIDIUM NGK PLUGS
BLOCK ACID WASHED
NEW WELSH PLUGS
NEW STEERING AND RACK BOOTS
REBORED TO 2.7 LTR (ROUNDED)
HKS POD FILTERS
HKS BOOST CONTROLLER
HKS TRIGGER SYSTEM
BLITZ TURBO TIMER/BOOST GUAGE
TRUST INTERCOOLER
ARC B.O.V AS WELL AS 2 STANDARD
GATES RADIATOR HOSES
REMOTE OIL FILTER RELOCATOR
REMOTE OIL COOLER
NEW CRANK ANGLE SENSOR
GENUINE APEXI 17 X 9? MAGS
NISMO BOOT LIP
N1 BAR SLOTS
TRIAL SIDESKIRTS
NISMO REAR PODS
APEXI REV SPEED METER
CLARION IN DASH LCD SCREEN
IN DASH DVD PLAYER
VEILSIDE GEAR KNOB
RAZO PEDALS
BLITZ BOOST GUAGE/TURBO TIMER
PIVOT SHIFT LIGHT
[email protected]
$32000 ono
have heaps more pics
I can help arrange transport for the car if interstate etc
Rebuild was done 2500k's ago
I am going to get a power run done next week
Bilstein suspension
speedo chrome surround
arc 3rd BOV
rebuilt starter motor
strut brace
relocated the a/c into the glove box with boost contoller
Isotta steering wheel
Razo pedals
anyone?????
Yeppoon is near Rockhampton...I think the CPU was chipped but I can't confirm that so I didn't mention it. Had it sold but finance fell through.
The only thing I didn't get around to getting was the Power FC
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
