Initial Drift is proud to present, in association with Evo Motorsport:
D-DAY CHAMPIONSHIP NSW 2005 - ROUND 3 at Wakefield Park.
The third round of the Initial Drift D-Day drift championship 2005 will be held at Wakefield Park on the 2nd of July 2005. A full morning of practice, followed by qualifying, then a top sixteen battle to win!
Spectators more than welcome. Full cafe facilities and plenty of parking available at the track.
DETAILS:
  • Gates open at 7:30 AM
  • Entry is $100 for club members, $150 for non-members.
  • You will either require a CAMS L2NS licence, CAMS day licence or Wakefield Park licence, all of which are available on the day.
  • Please register HERE. Payment up front will secure you a spot.
  • All cars must pass CAMS scrutineering - no fluid leaks, batteries must be clamped securely, seats and seatbelts must be safe, any harnesses and roll cages must be safe etc.
  • All drivers must wear non-flammable clothing neck to ankle to wrist, and wear a Australian Standards 1698 approved helmet (like a motorcyle helmet).
  • Judging and full commentary by the Initial Drift council.
  • For directions to Wakefield Park, CLICK HERE.
  • Wear warm clothes - this is Goulburn in July we're talking about.
  • Bring lots of tyres!
The results from Round 1, which was held on the same track, were as follows:
1)Michael Spencer - lime green Onevia
2)Chris Easton - black/silver R31
3)Greg Host - black JZX90 Mark II
4)Stuart Borrows (Noddy) - maroon R33 GTS-t
5)Jarich Van Horch - light blue Gazelle
6)Pete Carruthers (Fatz) - black R31
7)Nathan Weissel - blue VL turbo
8)Mark Watling - Multi-Colour R31
9)Fernando Wiehrl - black/gold Sileighty
10)Anthony Bilic - dark green S13 Silvia
Edit for Skylines Australia forum: Look at that - four out of the top ten were Skylines. Come along and prove you're better than Fatz and Chris. :)
Round two results will be updated here soon.
Prizes include a Hybrid FMIC kit OR a DRFT body kit, an X-Force stainless steel turbo-back exhaust system and an X-Force stainless turbo manifold.
A pack of cable ties is awarded for the best crash, as well as trophies for podium finishers.
Take a look at some of the photos from round two HERE and round one (as seen in Drift Battle magazine) HERE.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
