im a bit confused :confused: with filters now i want to keep my orig. air box it seams to be the a good option performance wise ,now so far i am looking at the followin flat panel.
apexi $100
nismo $160
k&n $120
and am wondering witch is better or if they are all the same.
https://www.sau.com.au/forums/topic/78101-air-filter/
I've heard Apexi panels are good. But you're probably better off getting a pod and sealing it while feeding it with a CAI pipe from the front of your car. Will make it much better - power wise and you should get better power economy too. Oh and its all legal! :)
https://www.sau.com.au/forums/topic/78101-air-filter/#findComment-1426609
Cut your airbox and run some CAI piping to it with a KnN hi flow panel filter, will do the trick very well :(
A pod filter with CAI and heat shielding may be slightly better but not noticeably and will cost you alot more than using your existing box and some home modifyin
https://www.sau.com.au/forums/topic/78101-air-filter/#findComment-1429489
apexi  $100
nismo $160
k&n $120
Where are you getting an Apexi Panel Filter for $100.00 ??
Interested as I'm going away from a pod and back to the box.
https://www.sau.com.au/forums/topic/78101-air-filter/#findComment-1440620
Pods are defectable because they're modified equipment.
Their legality has nothing to do with being boxed.
It just needs to be engineered.
https://www.sau.com.au/forums/topic/78101-air-filter/#findComment-1440836
i know im going to get in trouble for this, but ive been wondering for a while....
why not just use the $29 ones from super cheap auto (they look exactly the same, even on close inspection!!)?? (ducks in readyness)
Or a $12.50 original Nissan one...
https://www.sau.com.au/forums/topic/78101-air-filter/#findComment-1441050
  • 3 weeks later...
Hey guys, I'm also wondrin wat i shud do wit me air intake... was originally thinking of just stickin a K&N pod on the end, but am now feeding that wit some cai piping from the front. wud be grately for any pics ppl hav of their setups, or comments.
also, with some of the reading i've been doin, ppl suggest that just getn a good panel filter and puttin it in the stock airbox is good?
https://www.sau.com.au/forums/topic/78101-air-filter/#findComment-1469359
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
