After studying :confused: (yeah right) RB engines for a little while, i noticed a couple of years back, twin turbo RB25's were kinda popular, especially in VL's. So I was wondering if any of you intelligent humans know if the standard GTR manifold can fit the RB25, or is custom the only way to go? Any help would be greatly appreciated, cheers
The inlet and exhaust manifold stud patterns wers made deliberately different by Nissan to stop people from putting R26 manifolds on RB25's. They believed it would increase the exclusivity of the GTR and support its higher price.:rofl:
Gee that only leaves 100000 other parts that will fit :(
By far, most of the parts that give the RB26 the extra performance are not interchangeable. Things like cams, valves, valve springs, followers, injectors, inlet manifold exhaust manilfold, inlet plenum, throttle bodies, turbos, dumps, engine pipes, inlet air temp sensor, ECU etc
Sure I can use the same spark plugs, oil filter, CAS, water temp sensor etc but they are hardly what I would class as "performance" increasers.
:rofl:
I fitted the twin turbos off the R34 GTR to my GTS25t track car. The manifolds fit after cutting and welding 2 of the flanges, then match porting. Everything then just bolts up like the exhaust. It's not easy or cheap.
Hi Gtr Geoff,
Just interested in how well the GTS25t went and what sort of power it made?
Did you use standard gtr turbos?
Cheers!
A lot of people look into this idea . SK costed out the cams buckets springs etc to mod a R33 25 head , buying the GTR head and manifolds is far cheaper .
I'm not disputing that Nissan made it difficult to fit GTR manifolds to any other RB head , but when comparing them too many things get in the way to make it practical . Obviously the RB20 pattern came first and the GTR type later . It looks impossible to fit the GTR inlet on the alternate pattern because there would be no access to the fasteners . The exhaust stud pattern has the same dramas for the same reason . The two flanges would have been changed to give access to the nuts and washers around the twin turbos .
Bang for buck using the complete RB26 top end (turbo/s optional) is best from a performance viewpoint if you can afford it . Being non VVT it solves the oil drain problems as well and another reason why I bought mine .
Cheers A .
It was feeling nice.
Unfortunately the stock (see ceramic turbines) front turbo decided to let go at 5psi and I now have 25psi compression on 1,2,3. This is appearing more common than I initially thought possible, but when the ceramic turbine let go on this setup (RB26 style) it is often ingested back into the 3 cylinders and scores the bores and stops the valves closing.
I would never do this again with the stock GTR turbos as they tend to be more prone to failure after being removed. That said, it would be too expensive to bugger with using expensive turbos. I think I will be dropping in a complete RB26 for a number of reasons, although they aren't as punchy low in the rev range.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
