The reason why they only took photos from behind was so the flash didn't blind and/or scare the driver, potentially causing him to swerve and cause an accident.
Do you know how they have overcome that problem?
https://www.sau.com.au/forums/topic/7819-speed-cameras/#findComment-114221
reason for not doing it was cause motorbike dont have a front number plate so its descrimination.
however you will c motorbikes with front plates very soon
also fixed speed cameras generally only work in one direction
very soon they will be bi-directional
dont know about the technology for the flash just know about the cameras
prime example being the mount ousely (woollongong) cameras that will start working shortly
pete
https://www.sau.com.au/forums/topic/7819-speed-cameras/#findComment-114232
Dunno about them worried about 'discrimination'... I'd say they were more worried about losing a few bucks due to not being able to identify the vehicle.
Good luck to em getting a numberplate on the front of many bikes... there's nowhere to put it. I know on my bike, the only places it could possibly go is:
1) Over the headlight
2) On the windscreen
3) Below the headlight, fouling on the front wheel at full travel
And not one of those areas could satisfactorily accomodate a large, flat plate. They are a bunch of tossers.
https://www.sau.com.au/forums/topic/7819-speed-cameras/#findComment-114666
fatz, do you have any more info on this? Like how much of my wages will i have to put aside to pay the fines for non-compliance?
Ferkin bureaucrats and politicians can go and take a flying .... :cuss:
https://www.sau.com.au/forums/topic/7819-speed-cameras/#findComment-114680
The real reason behind NOT taking pictures from the front of the vehicles was privacy laws. Wouldnt be great disputing a fine, having the picture sent out to you and your wife standing beside you when you opened the letter with the pic showing your girlfriend in the passenger seat. It was brought about by the privacy act.....
https://www.sau.com.au/forums/topic/7819-speed-cameras/#findComment-114751
Guys I have been issued with a speeding fine, which was photographed front on I asked for the photo and the photo is that clear that if i was sticking my toung out you could see it. By the way this was taken almost two years ago. I'll get it scanned and put in on the forum.
https://www.sau.com.au/forums/topic/7819-speed-cameras/#findComment-114845
no there wont. this argument/discussion/debate comes up a couple of times a year and both sides stick vehemently to their guns saying that they have it from a reliable source etc.
well, here's a thought.
check the back issues of AMCN and Two Wheels for the past 10 years and you'll see that it has become such a long tradition that they now have April fools jokes in these and other publications saying that this will take effect as of (insert date here).
In short Rubbish.
privacy
na they just blank out everyone except the driver, so this no issues there
Beg to differ. Privacy legistlation (IN THIS STATE - NSW) says that you can't. This needs to be ammended and as of today (27/12/2002) it hasn't been.
also fixed speed cameras generally only work in one direction very soon they will be bi-directional
Sorry, but this is incorrect too. The cameras at the bottom of Ousley are on the other side of the road to what we're used to, i.e. the same side of the road as you is USUALLY the side that takes the photo. Not in this case. You will notice that when next you drive past them that they are placed so as to catch all lanes in both directions.
e.g. The South bound camera is on the Western side of the road and catches ALL 3 lanes. The two coming down Ousley as well as the traffic from the on-ramp and the lanes from the gong heading south... NOT the two lanes going towards Sydney.
Similarly, the North bound camera is on the Eastern side of the road, staring you in the eye as you round the bottom bend of Mt Ousley Rd on your way down. This is so as to catch ALL traffic Sydney bound and not just those BEFORE the Uni on ramp.
Worth it for you Sydney guys to keep an eye out cos you wont notice them straight away. Of course, as with all fixed speed cameras, they have to be posted and they are not yet. I imagine that they will pay for themselves fairly quickly though.
All the best,
Adrian
https://www.sau.com.au/forums/topic/7819-speed-cameras/#findComment-115092
mt ousley speed cameras r on trial for oncomming traffic not bi-directional (fact).
im led to belive that they use a standard flash (which doesnt sound to safe to me)
another reason for taking the oncomming photo is cause they can get truckies that speed.
just make sure that you slow down earlier
pete
https://www.sau.com.au/forums/topic/7819-speed-cameras/#findComment-115993
My only speeding ticket was from a car-mounted camera, taken at night, from the front, with a bright flash. In early-ish 1999, in Sydney. I was going 72 in a 60 zone in the middle of the night with no other cars around on a wide and brightly lit road. I wonder how many lives were saved by that ticket I got :P
https://www.sau.com.au/forums/topic/7819-speed-cameras/#findComment-116449
Well, exactly 12 lives if you believe the 'every k over is a killer' bullshìt :D
https://www.sau.com.au/forums/topic/7819-speed-cameras/#findComment-116463
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
