Hey all,
Has anybody seen tail lights like this around, any idea where they might have originated from?
I've just bought this car and I'm not 100% sure I'm keen on how the rear-end looks at the moment... let me know what you think.
I would love to get one of the illuminated "Skyline" panels, so if anyone could tell me where to get them i'd appreciate it.
https://www.sau.com.au/forums/topic/7832-r33-tail-lights/
Guest Boxhead
Originally posted by Stoffle
Hey all,
i dont know about where to get them but i rekon if anyone did know where, they would keep it a secret, coz the red afterburners are the trade mark of the skyline...
https://www.sau.com.au/forums/topic/7832-r33-tail-lights/#findComment-114543
Some bodgey Japense bastard had cut the wires on mine so that only the outside two tail lights illuminated.
All 4 would light up for the brakes though.
It was quite cool as no one could pick mine as a Skyline from a distance.
I have since re wired it so that I have the trademark 4 stove plates.
I couldn't bare bieng different, but I think clear is cool
https://www.sau.com.au/forums/topic/7832-r33-tail-lights/#findComment-115532
I probably would've liked that... i kinda dont mind the R32s with the single light kit (so they lose the inner afterburner) but i think that's just because i dont like the 32 lights anyway... the rectangular indicators...
Before I bought the 33 I thought that the inner circles of the taillights were actually lights not just reflectors, I was going to make the outer circles into indicators... so much for that idea...
https://www.sau.com.au/forums/topic/7832-r33-tail-lights/#findComment-115841
Originally posted by darK
that would have been a excellent idea stoffle...
it would have looked pretty nice...
maybe its possible to make the (now.. stay with me here...)
the 2 outer parts of the inner lights into brake lights.. and the 2 outer parts of the outer lights the brake lights.. or vice versa... something like that? would that be possible?
You lost me... :confused:
https://www.sau.com.au/forums/topic/7832-r33-tail-lights/#findComment-118236
We'll I've decided I'm gonna give it a go... make the outer afterburners indicators, the inner ones brake/tail lights... i might make the standard rectangular indicators into brake lights or something too if i can find one of those illuminated 'skyline' panels (apprently they're actually a factory option?). I gather though that this might cause some problems with the boys in blue??
Shouldnt be too difficult though as all of my rear lights have clear lenses... so it'll just be a case of getting the coloured bulbs as Mud said.
https://www.sau.com.au/forums/topic/7832-r33-tail-lights/#findComment-118383
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
