as the thread states
i just took my mags of 2 clean em and there are a few chips in them some of the clear paint has striped of scratches .. put it thisd way i cleaned them as they still look bad .....so fresh paint and fixing is the way any ideas where 2 go in adelaide??? prefer down south some where so i don't have to go 2 far
cheers
https://www.sau.com.au/forums/topic/78401-repair-to-mags-where-2-go/
yesh got the rubber off today im might get them stripped and polished by a metal finisher and just one rerolled as it has a small dent on the inside by extensive wheel
i know what ya mean over the phone quote at least $100 per rim and then $100 per rim to reroll could be more , they good wheel 17" stern from japan hith deep dish on back but they aren't like the best so i don't wanna spend heaps on em special when i can pick a set of boost r rims with new tryes for $1200 i was on the mark if they cost me $500 or more i'd get new rims and use the old set for track use/driftin if i ever give it a go
turns out i got adelaide rim to re roll the 1 mag
and im pullin them apart at the moment they are 3 piece mags
hopefully on monday i take to a metal polisher and get it back in a few days
polishing cost me $80 a rim if anyone on here does this work and is interested let me know
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
