Do it Nick!
Slightly lowered with a set of deep-dish rims really sets off the flared guards on them.
Throw on a pod and chunky exhaust, maybe some cams, and have it nicely tuned, and whatever you lose in lag and outright power on the GT-R, you can make up for in response.
  • Replies 123
i just phoned jspec imports about one of these, he said for a 350gt premium which is 3.5 litre, it will cost 38k plus 4.5k compliance that for a 6speed manual, but he said you could get a 2.5 litre one cheaper but they dont have brembos and a few other options.
hey guys, we've been actively pushing more and more V35's because we wanna drum up interest in these great cars. Most people are put off by the non RB stature, but seriously if you get over that mental hurdle, the V35 package is very good. Better handling and performance than a Z33 (compare to V35 coupe) or the new Maxima (compare to V35 sedan). The compliancers we work with regularly also have expressed interest in them, and a couple of them are waiting on paperwork to confirm that they can start complying em, so things should get cracking very soon.
Everyday we add V35's to the aucution examples to give folks a realistic view of how much these cars sell for, start at and availability.
Here's today's picks:
http://www.j-spec.com.au/list/auction.php?...p?date=06/07/05
you can check out how much yesterday's ones sold for here:
http://www.j-spec.com.au/list/auction.php?...p?date=05/07/05
oh and check this out:
someone had to do it :rofl:
i just went to the company next door and they have one of these in there shed i must say i was in my element with about 5 r32 gtrs and a 350gt surrounding me ha ha.
But the company is called Shogun Carriers located in brisbane, they said they will be doing compliance for the 350gt within a few months they are still in the testing period.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
