Hey guys im new to these forums im Adzi........
Ive been looking into the r32 gtr latley and must say am very impressed i always thought skylines were a lil overrated (bro-inlaw beat a r33 gtst with a non-turbo supra) a mate of mine also owns a r33 gtst and isnt that quick to say the truth....anyway, i was looking at the stats for the r32 gtrs and saw something on the lines of 4.7second 0-100 13second quater out of a stock car.......i dont think ive heard of this stats from any car from late 80's early 90's......only car was the gt gtho phase III's but thats even before then......anyways ive been looking to get one hopefully next year ( i know long time but i want to do alot of research) and have been looking at some prices why can i see some gtrs yes gtrs going for 18k-20kish yet some others are around the 28k+ mark.......if it is possible to get a good condish r32 gtr for around 18-20 i willl be doing a fully rebuild of the engine plus a custom blue print among other things i have learnt from my past dealings with cars........
Thanks everybody and sorry bout the long post
https://www.sau.com.au/forums/topic/78944-r32-gtr/
Ok the 18k to 20k are offen 1989 or 90 models std with very few mods and plenty of km's, so they require a lot of attention to get them up to a reliable performance level.
The GTR up around 28k to 30k will tend to be 1992 to 94 or have been rebuilt or maybe even had some series upgraded installed. So generaly this cars you can just enjoy and don't tend to have to do a lot just for reliable.
In the end both units will tend to cost you about the same as the cheapy will not be so cheap, if a few things fail.
BIGGEST TIP what ever you do try your best to allow to replace the std turbos (even before concidering a rebuild) because a turbo failure can and offen does damage the motor and then your looking at big money. If you can't replace the std turbo's DO NOT turn the boost above about 12psi.
pete
https://www.sau.com.au/forums/topic/78944-r32-gtr/#findComment-1440777
gtr = money pit either way but if you want something straight and reliable with good interior 30K +.
but if you are intent on doing up the motor regardless, wait until you find one that's basically good but has a spun bearing or similar and negotiate. just remember you might need money for gearboxes, clutches possibly trans case rebuild etc.
https://www.sau.com.au/forums/topic/78944-r32-gtr/#findComment-1440827
they are only a money pit if you wish to modify them.
other wise good for daily driver.
ive hadmine baout 2 years ot a prob other then turbos, replaced with n1's car makes 300kw at the rears good stong car if looked after.
by the way standard car ran 12.1 at 114mph on standard turbos running 14psi....
woooossaaaa
https://www.sau.com.au/forums/topic/78944-r32-gtr/#findComment-1441512
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
