Just got myself a 300zx single turbo! the rear turbine is slightly larger than r33gtst, however, the flange to the rear of the turbine and the wastegate seem to join to the dump pipe! :confused:
Ian, does the 300zx flange bolt up the stock pipe?
  • Replies 316
Posted Images
The 300zx/VLT turbine housing is fine to use.. Its not a simple bolt up, it requires a new dump pipe. :D
I know of a bloke making over 300rwkw using a VLT exhaust housing and some GT30 or 35 thing on his RB25DET with cams. I'm unsure exactly what comp wheel its running.
Hfi zoom, sounds like you might have a VL turbo with the waste gate integral with the dump. The VG30 bolts up to the stock dump normally.
Ian
Now i am confused :confused:
When i posted if i could use a VL turbo ext. housing, i thought i read that the housing is not as big as the VG30 housing.
So what are the specs for the VL turbo ext. housing?
I know i will need a new dump pipe; not a problem.
Will the std. oil and water lines fit?
Any other mods required?
Please help as i am about to take my car to the mechanic and like to do this while i am getting cams and head work done.
The VLT Exhaust housing is around the .63.
From my understanding the Z31 300ZX turbo has the same hot side but runs a crappy small comp and turbine wheel.
I've attached a pic of a VLT 550hp highflow turbo.
Unsure on the exact specs but it was apparently a little laggy on the rb30et.
Ian
i was told by this guy that it's a 300zx turbo! Note taht the compressor side is quite small when comparing to r33!!
can anyone confirm that the waste gate integral with the dump is vl? :crazy:
Ian
the guy swear by it that it's came off the 300zx red engine single turbo 1988 model. The rear has 7 bolts which the same as "Cubes" attachment but the comp side seem similar but smaller!! :chairshot
Ian, what year is the 300zx you have got and it has the same exhaust flange to r33? :D
Thats correct, it most probably is a turbo from a 300ZX.
The turbo you need is NOT the one from a 300ZX but rather Cima/Leopard VG30DET that made 190kw at the fly in factory form. From memory they are around the year of 1992+. The very late models apparently had the largest of the turbo's, i've unable to find out for sure as every one imports the older VG30DET's from around 1992.
The pics I attached previously was a VLT turbo.
As I said prior also they are similiar to the single turbo 300zx.
I've taken a few pics of my Cima/Leopard VG30DET Turbo.
haha.. Sorry buddy.. Its going on the RB30DET.
The stock turbo doesn't suit the 3ltr at all. The power band is in completely the wrong area's. It pulls super hard from 2000-3500rpm then keeps pulling but not as intense, I then change up at 5k, reving just that bit more see's the next gear really suck as it drops the next gear out of accelerating power. :D
Come the new year I will machine up the exhaust housing to suit the GT30 600hp core. Hopefully it works well. I will obviously have a discussion with a few turbo specialists as the 600hp core 'may' flow too much air for the hot side to cope with creating surge etc.. Not something I want. :D
lol...
Patience is a virtue. One will show up.
I wouldn't ring the jap import places asking for a damaged one, I would personally go down there and check every individual turbo for stuffed bearings.
Then say.. oh this ones farked.. I'll give you $100 for the exh. housing.
Cubes,
Thanks mate, it's alot clearer now. I think what i've got is the 300zx single turbo 1988 model. i should have ask him for the VG30det rather the 300zx single turbo as i understood! :crazy: ....
i believe i have a VG30 turbo .. but i still cant be sure .. i was told it was.. but i like to be 100% sure .... it looks very similar to the one cubes has pictured. but the rear wheel isnt steel like earlier VG30's .... much like Cubes Cima one again .... i was told it came from Justjap some months ago ..
i wanted to fit it to my rb20 .. but i cant get the bastard water lines undone... bent a 22mm spanner trying to undone the outer water line banjo bolt. aint that a bitch!
Bass Junky .. i might be willing to sell it if your REALLY struggling to find one ..
VG30 sucks on the RB20.. :cheers:
Very soft hitting boost and it doesn't really start pulling hard until at least 4k.
I had a vg30 turbo on my old rb20 some years ago. Only lasted a week before I got sick of it and threw the stocker back on again. Stocker running 1 bar was much more fun and quicker. Maybe not at 7000rpm but the difference was really stuff all.
Mid range and average power is where its at. not peaky crap.
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
