Colour/Year/Make/Model
- Silver 1993 ECR33 Nissan Skyline GTS25t Sedan
Engine Accessories
- Trust 3" Straight Through Cat Back Exhaust and Muffler
- FLYN 3" Straight Through Dump and Front Pipe
- K&N High Flow Pod Filter with Cold Air Partition
- Hybrid 600 x 300 x 70 Front Mount Intercooler and Piping
- Blitz DD BOV
- Nismo Adjustable Fuel Pressure Regulator
- NGK BCPR6ES (0.85mm gap)
- Nissan GTR Timing Belt
- Nissan N1 Water Pump
- Nissan Genuine Idler and Tensioner Pulleys
Engine Management
- Apexi SAFCII
- Apexi SITC
- Autospeed Norgren Boost Controller
Driveline
- 4 Speed Automatic
- LSD
- HICAS
Suspension
- Stock Shocks and Springs
- Custom Front Strut Brace
- Whiteline Adjustable Front Castor Bushes
- Whiteline Rear Subframe bushes
Brakes
- Recently machined front Rotors
- RB74 Front Pads
- DBA Kangaroo Paw Rear Rotors
- EBC Black Rear Pads
- Castrol GP 600 Racing Brake Fluid
- ABS
Bodywork
- SAU Stickers
- Rear Carbon GT Wing
- Factory Front Aero Bar Modifications
- Phillips Crystal Vision Headlights
- Metallic 25% Window Tint
Rolling Stock
- BBS 16" Rims
- Bridgestone SO3 tyres
Interior Gadgetry
- Apexi RSM /w G Sensor
- Splitfire Boost Gauge
- HKS Turbo Timer
- Reverse EL Dash
- Momo Steering Wheel with Nismo Horn Button
- Jays Leather Handbrake Boot
- Aftermarket Alarm, Keyless Entry, Genuine Nismo Key
Stereo Componentry
- Addzest CD/MD Head Deck
Price
- $14000 negotiable for quick sale...(recently purchased for $15,500)
Story
- Recently purchased this car from Adrien Strutton in QLD for my wife, but due to an unfortunate change in financial circumstances I have to sell it.
- Well maintained mechanically, it drives faultlessly.
- Well worth the price as it has most of the modifications you would want to do to a standard car already done to it. (and save yourself thousands)
No expense spared...
- Complied 10/2002...
- Never crashed...
- Never let us down...
Contact
- Guy
- 0413 648 750
- Email [email protected]
- or PM me
https://www.sau.com.au/forums/topic/79440-r33-sedan-modified/
Price is $14,000 ono
I purchased the car a few months ago for a little more than this. At that time I thought I had a bargain. I am not gready so I will pass the car on at a good price.
I have had a PM asking if there is anything wrong with the car (implication being that with these mods the price is too low) but I assure you the car is in good condition with no faults that I am aware of.
I believe this is an ideal opportunity to get into a great car at a good price. You can purchase a new (to Australia) import with fewer km, but it will cost you more, and by the time you factor in all the mods that have already been done to this car you are well ahead.
Jeez I only just saw this otherwise I would have responded earlier... Tis a shame you can't keep it Guy :) Tis also a shame I can't buy it back :rant:
I'll confirm that this car IS a bargain at $14000... If anyone would like to know more about the car feel free to contact me and I'll help where I can...
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
