Ive now got 2 jaycar amps... a big pioneer sub and alot of wires in my boot......
has anyone done a decent install? has pics of one or any ideas... im thinking i might just make a false floor for maybe 3/4 the boot and mount the amps on that as i cant see any other way.... unless they are mounted upright in the boot against the seat......
anyone got pics????
or ideas??
thanks
ed
https://www.sau.com.au/forums/topic/79848-boot-install-r32/
I am currently installing and taking pics, so I will post when thats done...
I am mounting my 2 amps on a piece of MDF and trying to find a way to mount the wood somewhere so the amps look like they are kinds floating....having a bit of troubling with that tho
https://www.sau.com.au/forums/topic/79848-boot-install-r32/#findComment-1454666
hey all....
i was going to go with the angled look and amps at the front etc etc.... figured out most boot space would be from a non symetrical install.......
made a false floor in the boot of my 32 and going to have another floating floor......
its coming along nicely.... pitty mum took the didicam away otherwise id have some pics....
thanks
ed
https://www.sau.com.au/forums/topic/79848-boot-install-r32/#findComment-1462271
would be keen to see some ppls installs too, i was hoping to have a 12" sub in a box against the back seat coming out to where the wheel wells stop, but after some measurements im having fun trying to work out how i am going to actually do it now...
https://www.sau.com.au/forums/topic/79848-boot-install-r32/#findComment-1485576
haha yeah not much room... bit of a pain in the ass... i should have my install hopefully finished 95% tomorrow... will take some pics so u have an idea
https://www.sau.com.au/forums/topic/79848-boot-install-r32/#findComment-1485847
i had the same problem.......
mine is just about finished............
just need some vinyling/rice lights and she will be finished.... something different... boot space still useable and nothing under the parcel shelf......
with all the custom fabrication ive done i have a feeling you lot will want to copy the sizes/ patterns :rolleyes:
Teased u lot enough?
https://www.sau.com.au/forums/topic/79848-boot-install-r32/#findComment-1495472
Sizes/paternsorban  :(
yeah thats why i went with tubes instead of a conventional box due to the limited clearance in the boot of the R32's.
Got 2 in there (one on each side) and there is plenty of room still B)
Cheers B
https://www.sau.com.au/forums/topic/79848-boot-install-r32/#findComment-1498539
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
