The reason i tookt he starter out was to install a ring gear stopper. Im going to buy one 2morow. Not 100% sure how to install it though. Any tips?? By the way im locking it to undo the crank pulley bolt.. (new cam belt)
Ahh....well my 2c is that generally there are easier ways to get the bolt off than using a ring gear stopper. eg leave it in gear and have someone step on the brakes....might even be able to hold it on the handbrake.
Deren I have a tool to hold the harmonic balancer while the front bolt is undone/torqued. I'll check tomorrow to see if it fits the GTR as I made it for thr Soarer and it works ok for the RB25.
There is no way i would pull the starter off just to hold the ring gear .
There is heaps of other methods to use , like the starter , always works for me or what Duncan said but you will need a 3/4 drive socket ( 27 mm for gts and 30 mm for gtr ) and a good long bar . I wouldnt try 1/2 inch drive socket on the gtr it may break , they are very tight .
If i have the engine out i use a 3/4 " rattle gun .
Don't use a screwdriver on the ring gear you may break a tooth or 2 .
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
