Hey all...Pm's replied..
Jamie Your in luck yes i am selling my bootlid very shortly as soon as i get a mould of it for the carbon one...
It has a nismo rear lip on the boot aswell :unsure:
Pm me with an offer
cheera
https://www.sau.com.au/forums/topic/79997-gtr-parts/page/2/#findComment-1502020
hey all...
Have a few things i want to get rid of:
Will pay postage!!
- ARIAS PISTONS + RING KIT (BRAND NEW)
Suit rb26, Suit bore size of 86.5mm. Pistons are 20thou over. These are brand new and i can provide detailed spec's on the pistons if Someone wants them.
PAID : $1550
PRICE : $1350
- STANDARD GTR PISTONS
Excellent condition No Damage
PRICE : $ 200
ALSO
Have Full GTR R32 interior
-Dash
-consols
-roof lining
-Front seats SOLD
-Rear Seat
-Carpet
-all Side panels
-Foot panels (comp cover)
Plus more.....
Offers if interested in anything or we could work out something for the whole package......
cheers
After a seatbelt holder for drivers side of r33 1993.
https://www.sau.com.au/forums/topic/79997-gtr-parts/page/2/#findComment-1522834
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
