  • Replies 42
Hey DIRTgarage
we are leaving the twin shells at wallsend at 7:50 sharp, and picking gruntn up from the south bound caltex on the freeway. so we should be getting there before 9am.
if all us who are entering arrive at the same time we will get a spot together :)
just go to the other thread an let gruntn know you are a definate.
no worries DIRT garage are u , voona, sticky-dave meeting at the shell or caltex
ill be at the caltex at 8.00 sharp you guy's should be leaving at 7.40 sharp (latest) entry car's are supposse to be there at 8.00 and the show open's at ten i think the 2hr window is so every one can get parked and stuff.
if you guy's get to the caltex at 8.00 we should be there by 8.20-8.30. 2 more sleep's heheheive seen some people have to leave at 3am or something so we should try to get there around this time.
how long do you guy's think it will take to get to the caltex?? ill be there b4 8
well great to meet all you guy's today thank you again, that was a top day. there was some awesome car's there and great people, especially :Pimp2: the one's from NEWCASTLE :bananaman hehehehe cheer's fella's catch up with you guy's again and thankx for letting me tag along!!!!! :alcoholic
chris
lenno
josh ( road rager) hehehe
dave
dean
linton
well done N.S.W SKYLINESAUSTRALIA cheer's for the t shirt but the newi boy's deserve the credit !!!!!!
no!!! thank you abo-bob & all that helpt out. yeah i think i went for lunch or something saw your car 2 and nobody around!! with the turn out we had i think you would have been flat out allday.
it was awesome glad i entered. couldnt find paul(dirt garage to shake his hand either,sooo many car's :Pimp2:
yeh damn road ragers always curse when ppl leave there blinkers on :rofl:
was an awesome turnout had a great day caught up with everyone again
still feel sorry for the 200zr though damn workshops..lol
Guest DIRTgarage
you didn't look in the TAB or the bar??...lol I saw your car but no-one around it. Was coming over to say g'day when you were moving your car up the top....but then realised you were leaving.
i was going to have a beer but if i start i find it hard to leave. get any winner's lol that bloody ramp weren't good nearly came off :chairshot cant wait4 pic's (chris)!! did anyone get pic's of our car's cause my wife left my camera at home :chairshot
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
    • As I wait for parts to be delivered, I have managed to procure via a contact a R32 Nistune ECU......for now I just want to monitor what the car is doing but eventually.......who knows where we go 😂
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
