  • Replies 58
Yea the blue GTR is one mad machine. It was running a very tame setup at track day as it is yet to have its power tune. Next track day expect to see nearly double the power, 9" slicks on the front, 10" slicks at the rear, side pipes etc and have a look under the bonnet !!
It was a good day, despite the rain.
I only had to pull three vehicles out of the kitty litter - Good old Cruiser.
The next track day on the 30th November is going to fill fast, so please secure your spot ASAP.
Can't wait to see Michael's Blue 32GTR in full force next track day, Paul may even get some laps in his 32GTR.
Regards,
Tim
I've added the wet times :D
Next one is the Grand Finale of the year on November 30. Stay tuned for the email soon.
Paul
if we can get enough interest can we have one earlier then Nov30 ?? and what about having it on a Saturday or Sunday ??
Paul you have email RE Photos
I also have a few photos will post soon.
Who ever owns the Red RX7, PM me as I have a great sequence of shots of your little indescretion coming onto the main straight :lol: Mud flying everyhwere :P Leave me your email address & I'll email them to you.
I also have good sequence photos of drifting the same corner from a couple of other silvias Car #25 & 26#. PM with your email address as well and I'll do the same. I'll leave the details of any other cars I have good photos of in this thread as I work through them.
Bring on the next one!
Cheers
Edited by TOY 33
SirSkyline,
You can email me at: [email protected]
Else you have my home email address from the track day mailing list. Although I will be trying to swith to the above as I now get heaps of offensive spam since I started track day.
Question for any administrator that may read this:
I am trying to convert to the MountainRunner login as it is the same as my login on other forums. Is it possible to change ownership of my Time Attack records thread from gtrman1992 to MountainRunner ?
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
