yeah, without a doubt........ my 2.5" systems is also holding my back will be going lrarger soon.
How would a 3 inch back to the 1st muffler and 3.5 inches from out of the 1st to the rear, as I had made a 3.5 inlet and 2 x 3 out muffler made up, when working on the RB25/30. As per attachment.
