  • Replies 71
あははははははhhahahhaha whats his name????
im not having trouble here im just studying chilling out ect
im still having fun its just all my mates are working or at school on weekdays so yea i only go out on weekends............see i feel like im on a holiday not doing much on the weekdays so i want to get busy..
I seem to remember a scary gaijin at Nanko called Streeter...
I tried to talk to him and he told me to do something that was physically impossible. He is best avoided.
Unforunately Nanko is a copfestival on Saturday night, so hopefully you enjoy standing around looking at beaten up old Nissans. There are only so many cans of coffee a person can drink while kicking the tyres of a Silvia.
Like Rezz said, Central Circuit... Also Meihan Sportsland. There is something coming up on a Saturday soon, but I work on Saturday so I don't know the details and CBF finding them.
http://www.central-circuit.jp/
lol..........maybe nanko sounds fun!! ^-^
i went shopping for a friendtoday anyone know any good shops to buy front corner clear lights for a s13 and rear clear taillights?? mu friend in aus wants them
i been looking but there expencive here..........ebay.com.au is alot cheaper
ahaha yea im yet to find the vendine machine that sells alive animals for you to keep.
i bought a asian condom as a joke because it was really small but ................they were real ahahahaaaha
look in the fleamarket(kansai) and theres a gaijin selling gaijin condoms its hilarious
Since moving to Japan condoms have never fitted better!
just smash them
Nah man, these guys are hooked up. Yakuza, Koizumi even Ayumi Hamasaki... all the big J-gangsters! You would end up like Andy Garcia in Black Rain
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
