Normally oils dont help a worn viscous diff because the viscous unit itself is sealed and uses its own internal fluid. Normal clutch or torsen type LSDs use the diff fluid's frictional characteristics to lock up so changing oils in those can help..
When I looked in to it a reco viscous is not an option as the the thick fluid stuff that makes the lsd a lsd is very very difficult to get a hold of.
The only real option is to shim it up. It costs around $350 or so. I'll be doing this as mine is stuffed.
Mine has been single spinning out of a corner now for 30,000km's.
Its now got to the point where its spinning one wheel in a straight line, it does this in second also.
So yer.. no traction for me. Sucks.
I've seen quite good results from shimming diff's.
Providing they are treated right and not consistently drifted they are fine and last quite a while. Well worth the $300 odd anyway.
He probably didn't want to shimm it. :)
Thommo - you said you took yours to Unique - how much did they charge you to get the diff+gearbox oil changed?
I'm looking at giving my car a major service - and reading this looks like my diff's on the way out as well, don't push it too hard but when I do tyre's light up on the right side, in the wet they just spin the whole way up the street - although i'm not sure if this is just 1 wheel (right) or both.. if it's both it's fine.. if it's 1 it's not..
Hey mate,
it was $260 - not the cheapest I guess (oils - 10% discount, plus one hour labour), but I don't have the tools / energy to know how to do it :)
Damn 1.5 way LSDs are expensive, i'll just deal with not being able to do dumb stuff in first gear for the moment I think :)
Cheers,
Tommo.
in my r33, when i am going below 15km/h around a tight (90 degree) corner the inside wheel spins easily
but when i am pointed straight ahead, in first gear both wheels start spinning and continue spinning at the same time for sure even on the spot
Thats pretty much what a healthy standard LSD does....they are limited slip but they are pretty loose from the factory so that they don't skip around like a nice tight mechanical diff would.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
