32 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
oh really people, shut the **** up about this. Its being covered 10000000000 Times, Just search it. The forum is getting crowded with useless threads about the same shit.
Dude that could have been said in a PM and ended it with something like...This has been covered too much or whatever, instead you have showed what a huge (ego) you have :D
*Just a thought buddy*
nuh, not really. Just really. This R32 vs R33 thing is a never ending thing. Search the forums and u will find sooo much. Its a conversation that will not have a conclusion. One likes r33, one like r32. Your not going to change anyones minds! So simply get over it :D
they've both got there good and bads at least there imports i say!! i dont like series 1 r33's but series 2's are kool but i love my 32 its awsome the look mean as with a gtr bonnet too. and dont get beat much by the 33's thou!
A bit off subject but I think that recently the r33 has largely been chosen over the r32 due to it being a relatively new car. But now that both are "old", the r33 wont have that "new" appeal advantage, and the r32 will be more appreciated. Not to mention the usual reasons - r33s are too FAT, and handle less well.
Its a matter of opinion. But the facts R33 is roomer and has a better more powerful engine, r33 is 100kgs heavier but still quicker in a straight line. Ive heard R32s handle better but im unsure on that one.
I prefer the looks of the R33, inside and out. R32's are starting to look a bit dated.
how are you "unsure on that one" ?
its 100kgs lighter and smaller all round and everyone says it (not always a good indicator ill admit) but it obviously has better handling
To the original thread starter, please stop being vague about what you want. State clearly ALL your requirements, eg:
your budget for the car you want to buy
your allowance per week that you can spend on the car (so people can tell you if you can afford an R32 GTR or an R33 GTSt, even though they will cost the same to buy)
your priority in the car you want, ie getting value for money or having creature comforts
performance is a very broad subject. Are you after a fast car, a car that handles well, one that has a responsive steering, one that is cheap to get good power out of etc. Please be more specific.
your use for the car, eg: build a show car, use it as a daily driver, not attract attention from police, experience driving a RWD etc.
This thread is now closed. If you wish to ask for help on what car is more suited to you, tell us more about yourself and what you want first. We have had many R32 vs R33 vs R34 vs krzysiu's mum threads before that really go nowhere if you want to read biased opinions that are of no use to you.
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
