32 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
oh really people, shut the **** up about this. Its being covered 10000000000 Times, Just search it. The forum is getting crowded with useless threads about the same shit.
Dude that could have been said in a PM and ended it with something like...This has been covered too much or whatever, instead you have showed what a huge (ego) you have :D
*Just a thought buddy*
nuh, not really. Just really. This R32 vs R33 thing is a never ending thing. Search the forums and u will find sooo much. Its a conversation that will not have a conclusion. One likes r33, one like r32. Your not going to change anyones minds! So simply get over it :D
they've both got there good and bads at least there imports i say!! i dont like series 1 r33's but series 2's are kool but i love my 32 its awsome the look mean as with a gtr bonnet too. and dont get beat much by the 33's thou!
A bit off subject but I think that recently the r33 has largely been chosen over the r32 due to it being a relatively new car. But now that both are "old", the r33 wont have that "new" appeal advantage, and the r32 will be more appreciated. Not to mention the usual reasons - r33s are too FAT, and handle less well.
Its a matter of opinion. But the facts R33 is roomer and has a better more powerful engine, r33 is 100kgs heavier but still quicker in a straight line. Ive heard R32s handle better but im unsure on that one.
I prefer the looks of the R33, inside and out. R32's are starting to look a bit dated.
how are you "unsure on that one" ?
its 100kgs lighter and smaller all round and everyone says it (not always a good indicator ill admit) but it obviously has better handling
To the original thread starter, please stop being vague about what you want. State clearly ALL your requirements, eg:
your budget for the car you want to buy
your allowance per week that you can spend on the car (so people can tell you if you can afford an R32 GTR or an R33 GTSt, even though they will cost the same to buy)
your priority in the car you want, ie getting value for money or having creature comforts
performance is a very broad subject. Are you after a fast car, a car that handles well, one that has a responsive steering, one that is cheap to get good power out of etc. Please be more specific.
your use for the car, eg: build a show car, use it as a daily driver, not attract attention from police, experience driving a RWD etc.
This thread is now closed. If you wish to ask for help on what car is more suited to you, tell us more about yourself and what you want first. We have had many R32 vs R33 vs R34 vs krzysiu's mum threads before that really go nowhere if you want to read biased opinions that are of no use to you.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
