54 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
yeah my S15 ones are chrome and I think they look great. Chapman thinks the paint job is sub-standard, but he is just fussy - they are just brakes after all!
Pics of the car in it's current state are below. (Note: the front-on pic looks like the car is on bricks, but these bricks are just supporting the front brake calipers - the car is actually on axle stands).
Sam, I agree with you - I am leaning towards gold.
However, in order to get my dishes polished (which needs to be done as the clear coat is breaking down), they will damage the silver centres paint job. Therefore the centre part need to be repainted. So I need to decide what colour to paint this - I am thinking shadow chrome - so maybe I would do the brakes the same colour? Or should I go gold? So many decisions ....
that R34 pic is hot Sam - but damn, does the owner have to lower the car!!! Looks like a 4wd :D - u could fit your fist between the tyres and guards
Don't think I'll go the pink Erica - was good for your 32 though ;) .... I actually have some metallic purple in spraypacks laying around here somewhere .... was going to paint up some of MattR's old burnt-up 32 wheels, but never got around to it. Maybe purple is the go? ;)
man why could you be bothered:P
jack my whole car up to paint my brake calipers you are crazy  wots wrong with original colour.
bet your misus walked out and went "wot the **** are you doing"
i know mine would :rofl:
actually i dont know if im correct but maybe andrew has jacked it up to check its overall underbody condition as well as replace the rims with stock rims all in the name of putting it back to stock for compliance so while he's at it decided to paint his calipers?
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
