Okay i need some advice regarding speakers. I'm noticing my stock speakers are starting to give a cracking sound- so i have decided too spend some money on the audio side of the car.
I wanna b one of these people with there system pumping- NOT lol
What brand is the best- I'm looking for speakers to put out 120 or above- the speakers have to sound good with BASS- i play mostly R&B, Rap, some dance and no devil worshipping music :twisted:
https://www.sau.com.au/forums/topic/82-6-by-9s-speakers/
Guest [ryan]
Just get some 6" coaxials man. Trust me on this one, DONT have a huge rear stage. Some 6" coax's would go nicely. Then upgrade your front stage, to soemthing like 6" 2-way splits or 3-way Splits and amplify them. Run rear speakers off the deck. Then later when you get a sub, your system will sound f**king NICE.
https://www.sau.com.au/forums/topic/82-6-by-9s-speakers/#findComment-2166
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
