It turns out I didn't blow the turbo, I blew off an intercooler pipe. But I couldn't see it on the night cause it was under the car and dark. But the turbo is definetly on the way out cause theres oil in the intercooler pipes. I'll drive like an old woman for a month or so and replace it with something a bit bigger. :D
https://www.sau.com.au/forums/topic/8271-hicks-is-happysort-of/
Originally posted by KILLER-T
I think a bit of oil in thr cooler pipes is normal if you are running a bit of extra boost just buy a oil catch can :D
im not too sure, I've had the pipes off quite a bit, when i painted them and polished the intercooler. also had the inlet pipe off when I changed the plugs(c#nt of a job) but theres never been oil in there before.
So what is new Hicks??:bahaha:
Good to see that your car is just barely alive, but I agree with Killer-T that it is probably not that much too worry about, but if you need an excuse to drive slowly then its OK with me.
See'ya:burnout:
It's scary when you blow a pipe off, does make you think the worst. I blew a vacume hose at the plex last time and I thought it was a dead turbo too. I had a look under the bonnet and found the hose, went out and kept dragging :D
Seriously sounds like blow by, this can be increased by increasing boost, or even using a oil thats a bit too thin when you change it. Would investigate a catch can as coating your coola isn't a good way of improving efficiency:D
Good luck getting it sorted - only if to get GTS-t VSPEC off your case....hehehehe.
Steve
Originally posted by GTS-t VSPEC
I never had oil in my pipes till I ran higher boost.
I run standard boost and have a bit of oil.
Catch-can you say ?
BTW: My next oil change is due shortly, what does everyone use/recommend ? and how much is it ? (also, how many Ls to fill up?)
-Kym.
Hes ripping u off m8.
U change ure oil every 5000ks right? whats the point of puttin redline in (unless ure a sheik or something) just use good ol Mobil1 synth half the price and will be dam close to as good as redline for that time period.
Its not just the oil in the pipes that worried me, its the way that smoke slowly rises from the exaust when I back it off after reving it.
BTW paul, your a tool. I might head down to the plex to watch you get some more 14 second passes. :(
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
