Hi Guys,
Ok, a lot of you are unhappy about the new forums, so hers a quick FYI for you
1. New styles are coming, I'll enable the use of the 'stock' style in the meantime, might make it easier.
2. IPB2 is a quicker forum package than VB, sure some options have been removed but I am working hard on getting them back
3. Please be patient, and document any problems/ideas etc in this thread of forum.
The VB smilies are coming soon, check your CP for options for the quick reply, you each have a blog now and I am working on a garage/timeslips registry + the trader ratings again.
If you are having problems with permissions, send me an email.
Christian
https://www.sau.com.au/forums/topic/82739-new-forums-please-read/
  • Replies 51
Mass updated everyones user accounts to GMT+10, so that should fix the problem for *almost* everyone.
This has been updated to be enabled by default for every forum now!
Lots of silly little problems, but in the end everything will be much better. The forum could have been kept offline for a longer period until everything was 100% but it's best to have it online I think!
Mcleod
Site seems to be pretty good..
One of the only things i miss though is when you used to hover your mouse over the topic title. it would come up with like the first paragraph or so of that post.
I thought that was a great addition and made surfing the forums much quicker :)
Either way. i think once everything is finished it will be better than the old one :)
hehe. *my 2 cents
hehe. *my 2 cents
I second that. It made browsing much quicker.
Also, people's location should be compulsory, especially useful in the trading section.
...One of the only things i miss though is when you used to hover your mouse over the topic title. it would come up with like the first paragraph or so of that post.
that was my favourate feature of the old forum!
pls bring it back?!
all in all, well done on the move, im sure all you moderators are working your fingers off getting it tweaked and sorted!
congrats and thanks for the hard work,
i know i would be very stuck without these forums :)
dan
Hi Guys,
Christian
Hi Christian - I suspect you are busy!
Is the 'stock' style something we have to pick (I couldn't find anything in the control panel) or is that what we are using?
If you need help testing styles etc, I'm happy to help.
Ian
ps As a rough rule of thumb, just about no web site works with a very dark background as the contrast with most colors - except white and yellow - doesn't work, with green and blue particularly bad...
Cancel that question!! I found it on the front page - and boy is the default one better!!!!!!!!!!!!!! I recommend everyone change to it!!!
Ian.
Yes i also miss this feature..
ANychance you are gonna bring this featuer back??? PLS PLS..
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
