http://www.skylinesaustralia.com/forums/in...=UserCP&CODE=04
Select 'yes' for the 5th option down - 'Open Fast Reply automatically when available?'
Didn't work... been trying for the last 15minutes
Please help!
https://www.sau.com.au/forums/topic/82744-want-quick-reply/#findComment-1497184
What happened when you tried?
I went to Control Panel
then Board Options
then selected Yes to the function for Quick Reply as per your post
then clicked Update
Nothing happens... forums still look the same :rolleyes:
https://www.sau.com.au/forums/topic/82744-want-quick-reply/#findComment-1497205
no, down near the 'add reply' button, should be a 'fast reply' option. I am working on the box being permanently there when the option is enabled.
No button to be seen anywhere... I'm sorry if I'm causing much frustration :rolleyes: Not intended, honest...
https://www.sau.com.au/forums/topic/82744-want-quick-reply/#findComment-1497262
nah mate, its all good. :rolleyes:
Helping me to iron out the bugs..
Can you try to change styles and see if the button is there - also, if you go back into your controls is the option as you left it?
https://www.sau.com.au/forums/topic/82744-want-quick-reply/#findComment-1497272
Changing it to the normal skin makes everything go out of place and jumbled... but more to the point, still no Fast Reply button.
Going back into my Control Panel, the settings are still as I left them. Yes is still selected for Fast Reply
https://www.sau.com.au/forums/topic/82744-want-quick-reply/#findComment-1497274
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
