  • 1 year later...
Just take it to any big panel beater shops, they can tell you if anything wrong, if u lived in VIC i could of told u a place but you don't so i really don't know, if u live near liver pool i could tell you my uncles mechanic shop he might tell ya what wrong, and he might tell where to go for repairs just PM if u want his location
i agree with trust33, check the hub. Exceller Steering would be my choice to check this kind of problem. This place is also one of SK recommended installers for his suspension groupbuys. They are located in Bankstown.
Like tdsepco said "don't stress - get some more advice. I race these things and have crashed one big time in the front. Even then the chassis was only slightly bent and I had it straightened. Every thing else in the front end bolts on and off - top/bottom arm, castor rod tie rod etc. if any of these bent you will chasing problems forever. Bit are easy to find and relatively cheap (on SAU) and not too bad from wreckers. Sometime all bits around from someone's half cut project.
Same goes for back - but heaps more moving suspension components. V V unlikely chassis bent - just some of the bits.
Suggest go to best frontend/wheel alighner you can find....pay for basic wheel align and hopefully they will tell you exactly what is wrong and what take to fix it.
Good advice may seem expensive first up, but WILL save you $$$$$$$$.
Kerry
apologies for the resurrection as well but i am looking to purchase a gtr that has had a front end collision with a high kerb....just under the intercooler....the impact has sheared off the 2 castor rods and pushed one wheel far enough back in the wheel arch to bend the trailing edge or the guard by about 2"
now the $64 000 question......do you reckon this would have bent the chassis or is it likely to be repaired with bolt ins??
now i know you guys don't have a crystal ball,but i am looking for suggestions re the chances of chassis damage...likely,maybe,definately,unlikely,etc
am i likely to be able to verify anything visually if i jack it up and take a decent butchers or am i wasting my time looking??
cheers guys
do you know any contact details for these guys mate?
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
