before everyone asks me to do a search could they please read my post below because i need help with my decision
i currently have a r32 gtst with full exhaust, filter, fuel ump and have a hks gt2530 and FMIC on the way. after that ill get a chip
here are the options i have
1) get a nimso fuel pressure regulator for $200 and be happy with say around 210rwkw
2) get GTR injector $250, get them cleaned $150, then get a resister pack $100. all up thats around $500
3) if im going to spend $500 on GTR injectors i may as well get nismo 720cc injectos for $600 off a friiend
the questions is this. do u people think i should just get the nismo regulator and see if that will push up to 220rwkw? because if i decide to get the injectors for a few more KW its going to cost that extra $500 and im a cheap arse
Guest DIRTgarage
Just check the impedance of those 720cc nismo's...you may find you need a resistor pack for them too.
p.s. lack of fuel is the main cause of engine damage/failure.....that is after lack of oil
the iibjectors may be 600cc or 720 but are the same impediance and are a direct bolt in ive been told. thats why i thinking about getting them over the GTR ones
and yes that is my main concern. i dont want to engine to be starved of fuel
I'd say go for injectors for sure
I had stock injectors making 200rwkw and it was dodgy at best
I have GTR injectors now, and at 205rwkw they are running at 70% duty, so the stockies where well past it
Some people reckon 220rwkw is possible out of stock injectors, but all dynos read differant
my 200rwkw stockin/inj was on a differant dyno to its current read out, so on the same dyno I reckon it would be 215+
It makes a extra 45rwkw midrange, as we could screw in heaps more timing and fuel with the safety of the bigger injectors
I'd go injectors for sure
am i missing something? (highly possible) you mentioned a chip but if you opt for bigger injectors you'll need a prog ecu or remapped stocker.
as you know that alone will give you a power increase. if you get a used pfc for $800 that's not much more than the cost of injectors and gives you much more flex. some people have had good results with increasing pressure - within reasonable LIMITS - as a 10% increase or thereabouts puts the pressure below the upper threshold stipulated by the manufacturer in most cases.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
