All parts are from my 32GTR. Selling due to upgrade.
Motor has been stripped, some parts from that are for sale now also,
* Standard Rods - $150
* Standard Cams - $150/pair
* Standard Oil Pump - $100
* Standard Harmonic Balancer - $50
* Standard Cam Wheels - $50 pair
* N1 Water Pump - $200***SOLD***
* Nismo Timing Belt, done bout 15,000kms gc - $30
* Sard Fuel Pressure Reg, Excellent street upgrade - $200
* Standard gtst drivers seat - needs recovering $30
* Momo steering wheel $150
* Standard 32 GTR ecu $200
* 1x Standard GTR Turbo with all fittings, great condition $400
* 1x Standard GTR Turbo, blown, no exhaust wheel $50
* Standard dump pipes $20
* Standard exhaust manifolds $50
* Rego Plates - OOR032, as seen in pic below $400 will upgrade to sell....
* HKS FCON computer. Has harness to plug into factory computer and factory loom. Full piggy back with no hard wiring in.
From what i've been told if your in Brisbane, Matt Spry from PITS on the Gold Coast can tune these, and if in Sydney, i would assume BD4's should be able to tune it seeing as they are the HKS distributor.
Pics of this to be posted shortly. $500
I need to sell parts a.s.a.p so all prices are negotiable. Located in Brisbane. Shipping at buyers expense and I will arrange for buyers. Pics to come shortly or as required. PM me if needed.
Cheers
Mike
Edited by dahandfull
https://www.sau.com.au/forums/topic/83188-gtr-parts/
  • Replies 63
Tbee - not selling the standard in dash speedo cluster.
dd4321 - Yes the one thats din mounted. And yes it will fit gtst. What is displays is Boost, oil temp and battery volts....
Chrisman - from memory it doesn't. the only tag i remember is a seriel number, but i'll check tomorrow for you
https://www.sau.com.au/forums/topic/83188-gtr-parts/#findComment-1515754
Injectors, harness, gauge cluster all sold.......
Zenith - i would like to sell the whole lot together because I have no use for any of the standard passenger seating (cage and race seats fitted).....
https://www.sau.com.au/forums/topic/83188-gtr-parts/#findComment-1518727
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
